Old 12-28-2012, 07:20 AM
chrisrees chrisrees is offline
Mein Auto: 02 745li
Tranny
What's different with the newer tranny's ? I know the 02-08 are designed to last 80,000 miles (lol). Is BMW still making them.
Repairs 2012
wishbone & steering rack
Rfmd hydro steering gea
combination nu
Ball Joint
Tension strut with hydr
Switch unit steering column
Coils 5&7 and new spark plugs
Faulty DSC Control Module
Fuel Gauge
Leaking Crank Case Vent Valves
Power Steering pump, washer pump and grommont,
Crank Shaft position sensor
Total $13,481.37 in one year my mechanic swears all these parts are re engineered to work better than the originals lol
Old 12-28-2012, 07:21 AM
Mein Auto: 02 745li
Or is someone else making the transmissions now?
Repairs 2012
combination nu
Ball Joint
Fuel Gauge
Old 12-28-2012, 04:08 PM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
The newer "Tranny's" have plastic surgery done... Da da dum...
Thank you very much, I'll be here all night, tip jars on the table folks...
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 12-28-2012, 04:21 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
BMW doesn't make their own transmissions, they buy them off the shelf from a company called ZF. ZF makes a multitude of transmissions for tractors to semi's to BMW's! BMW uses their own programming to run the transmission and control it's shifts.
The transmissions are different to an extent depending on your model. The 740's and 750's and B7 from 2009-2012 use the same transmission as the E65/66 from 2002-2008, the 6HP26Z from ZF. The X-drive models use a slightly modified version of the 6HP26 called the 6HP26Z-WHK
The Hybrid 7 uses a ZF transmission called the 8HP70H which is an 8 speed transmission with the hybrid motors and such inside. The 760 uses an 8HP90Z transmission which is an 8 speed, but it is built with better components to handle all the torque and power vs the hybrid.
EDIT:
As far as power ratings for the ZF trans goes heres what I found with a quick search:
8hp30 - 300nm (221 lb-ft)
8hp45 - 450nm (331 lb-ft)
6hp26 - 600nm (442 lb-ft)
8hp70 - 700nm (516 lb-ft)
8hp90 - 900nm (664 lb-ft)
Old 12-28-2012, 04:45 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
Originally Posted by popoemt View Post
the newer "tranny's" have plastic surgery done... Da da dum...
Thank you very much, i'll be here all night, tip jars on the table folks...
Lol.
2011 750i
Old 12-28-2012, 09:32 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Awesome, knowledgeable post; thanks.
EDIT:
