F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
first upgrage...
Got my fogs updated to match color today....Cree leds no codes and color matches perfect....
2013 550ix, Alpine white, M Sport package (me) 2012 X5 35ix, Saphire black metalic, (wife), 2006 325i , space gray (daughter) Retired: 2009 535i 2007 335i |
Where did you get them? Brand, model and retailer if possible. Did you do the install yourself? Was it hard to do? Did this on my Benz the hardest part was jacking up the front all the screws that had to be removed to take down the plastic cover underneath.
Super easy, just snap off grill around fog light. I found link I found link on forum " Cree 20 watt led bulbs" the one I bought are 40 watt and came with resistor modules so not to set codes. I went to amazon an searched for best price.... 80 or so dollars....
Some pics of instructions...
Nice upgrade while still keeping the OEM look.
2013 BMW X5 35i Alpine White | Cinnamon Brown | M Sport 2013 BMW 550i Titanium Silver | Black | M Sport |
Sweet, I am in for one! -since we don't have fog in Miami....
FYI- I hope you don't have fog in OK... The yellow actually helps cutting through it. What is th amazon link?? Last edited by Travel4Surf; 12-28-2012 at 04:14 PM. |
http://www.amazon.com/Bulbs-Headligh...6746370&sr=1-1
The link above is where I got them.... enjoy : )
Are these Halos or fogs?
The link talks about halos
I replaced the fogs to match color of halos and head lights.....
How is the pattern on the road at night?
So you order these 20w LEDs and the shipped you the 40w version? |
H8 and H11 bulbs have sams socket . Link shows halo bulbs but they work great down low as well......
Yes.... ordered 20 watt and when they arived they were 40..... I posted pics of the instructions below pics of lights installed....
Have not driven at night with them yet......
So did you order the H8 or the H11? I would like to do this as well.
2013 535i Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD Redelivery-12/14/12 |
As far as I can tell H 8 and H 11 use same base. The ones I installed are H8 and worked fine
How did u snap off the front grill to get to your fogs? Pic's? I've been having a hard time trying to do mine and afraid it's going to break. Thx
2012 535i Alpine White | Oyster Black Dakota Interior | Dark Wood Trim | M-Sport Pkg | Premium Pkg | Tech Pkg | Heated Front Seats | SAT | BMW Apps | Born on 1/30/12 Gre8tW8LL |
grill removal
I used a hook tool and started at the top corner....
Once you get the grill off trere are 2 8mm bolts on the bottom of the light assembly. Remove bolts then there is a tab on the back top of the light push the tab up and th ligh slides out the front to disconnect tht connector.....
Thx Kcustom!!!
Is it the tiny rectangle tab you're referring to press?
Nvm, I end up just twisting the light bulb harness, pulled it out then squeezed the tabs to replace the bulbs. Thx again for your help.
How do you guys like the lights... Driven at night with them yet?
Minha patroa é um BMW |
Just to clarify (since I do not have the car yet). The fog lights are normally yellowish-white but the halo ring and the headlights are normally the led white color like the ones you installed in the fog lights? Or are the halo ring, headlights and fog lights all normally yellowish?
http://www.bimmerfest.com/forums/sho...0&postcount=20 As stated: Stock on left side, replacement on right. Sean |
#25
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
