E30 (1982 - 1993)
Old 12-28-2012, 02:33 PM
dliff dliff is offline
Mein Auto: 1986 325e, 1984 Rabbit
Control arm replacement.
Hello all,
I'm having a difficult time replacing the front drivers side control arm. I have removed the bushing, the 22mm nut (that was a lot of fun..) and the nut on the steering knuckle.
All the nuts are off but the control arm is stuck by the ball joint on the hub. I've tried hammering a pickle fork in it, hitting it repeatedly with various size hammers, heating it up with a torch, cooling it down with ice, hitting the actual metal that surrounds where the ball joint stud goes it, and still no luck.
I guess at last resort I can take the assembly to a shop and have it pressed out. Must I remove the entire coil-over to get the hub out? It appears so.
Thanks for any suggestions...
Old 12-28-2012, 09:52 PM
james.e30 james.e30 is offline
Mein Auto: 2003 X5 3.0i
The right tool makes all the difference.
Go to Auto Zone and rent their ball joint/pitman arm puller kit. It comes with 4 or 5 different separators and one of them will fit your ball joint. You put the tool over the ball joint and tighten it down with a wrench. This will apply slow even pressure and the joint will separate. You can have this done in 5 minutes.
Then throw away your pickle fork. If you are going to do this more than once, or need to separate a ball joint and steering knuckle but aren't replacing the ball joint, buy the correct size tool outright. It lets you get everything apart without destroying the boot on the ball joint.
Old 12-28-2012, 11:48 PM
BMWFatherFigure's Avatar
Old School
+1 - the right tool every time - even if you rent it to start with. Once the tool is in place and tensioned up one good blow on the housing should pop the joint.
Current:
E38 Parts Car
Previous:
Old 12-30-2012, 09:44 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
You need more hammer.
m
Old 12-30-2012, 02:01 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
canned ice may also be useful
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
