Old 01-06-2013, 11:21 AM
911euro 911euro is offline
Mein Auto: 745il
Also is there a special tool for this job?
Old 01-06-2013, 12:19 PM
745iguy's Avatar
745iguy 745iguy is online now
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
straight from the horses mouth to you
as you will see from the pictures its pretty straight forward, and you must make sure that it is seated in properly, when i did my VCG on the driver side I had to put some force to get it back in with the new o ring on
ID:	356240   Click image for larger version
ID:	356241   Click image for larger version
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 01-06-2013, 12:34 PM
745iguy's Avatar
+1 on swapping banks also
PREVIOUS 2002 745i
Old 01-06-2013, 06:27 PM
SFbay SFbay is offline
Mein Auto: BMW 745i
Originally Posted by 911euro View Post
could you please point them out to me where are the intake and exhaust CPS from these pictures? gosh feel so stupid
thanks
Remove those plastic bmw covers from heads first
You'll see 3 sensors there:
One round is valvetronic
2 other ones are cam sensors
Old 01-13-2013, 10:00 PM
Mein Auto: 745il
i checked everything but could solve the problem. i finally consulted with a bmw mechanic, he asked me to bring the car over for him to check. he hooked up a professional scanner which he called it a euro typed scanner. It indicated that the problem was with the CRANK shaft position senor. He then hooked up the scanner he called Japanese scanner and it showed a camshaft position sensor. So i asked him to replace the crank shaft position sensor and the problem went away. I was not aware of scanners specifically for euro cars versus japanese cars.
anyway guys, thank you all so much for all of your advice and support.
