Old 12-30-2012, 09:25 PM
GabesJH82 GabesJH82 is offline
Mein Auto: 2002 BMW 530i
Upgrade speakers brand?
Looking to upgrade my speakers on my car since the stock don't have a really good sound on them especially when you have none dsp system. Just want to upgrade speakers only to have a good and better sound. Any good brands out there at a low price?
Old 12-30-2012, 09:33 PM
the540wgn's Avatar
the540wgn the540wgn is offline
Mein Auto: '02 540iT
If you want to keep your OEM head unit the easiest option is the BSW kit
http://www.bavariansoundwerks.com/ca...aker-Packages/
This topic has been discussed quite a bit, don't be afraid to search the forum
my wagons faster than yours
Old 12-30-2012, 09:40 PM
Thanks I heard of these before but 600 sounds a little bit pricey
Old 12-30-2012, 09:48 PM
the540wgn's Avatar
oh wow they bumped it up $100 since the summer..that sucks lol
Also check out boston acoustics, I believe some members have used them here
Old 12-30-2012, 11:13 PM
theWalkinator theWalkinator is online now
Mein Auto: 2002 BMW 540iA
Check crutchfield, they have a lot of speakers at different price point, Polk is pretty good, Focal is the best.
Old 12-31-2012, 04:55 AM
Fudman's Avatar
Fudman Fudman is offline
Polk, Boston Acoustics and Infinity all make 5.25" componenet sets that will swap with OEM (Nokia) speakers. Replace the front door speakers only to save $ as the rear deck and rear door do not add much to the overall sound quality. Most importantly, add a powered subwoofer as the current system lacks bass response. Go big, if you are in to the ghetto sound. Or just add an armrest subwoofer if you want to round out the overall sound. Do a search for the DIY.
Old 12-31-2012, 05:18 AM
mpower997's Avatar
mpower997 mpower997 is offline
Mein Auto: 97 540i/91 318is/04 330ci
Here you go lol http://www.bimmerfest.com/forums/sho...d.php?t=279416
Old 12-31-2012, 07:37 AM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
http://forums.bimmerforums.com/forum...0#post25630510
Here you go sir. Lots of great stuff in there
I got a m5!!!!!! If first you don't succeed you must try again
Old 12-31-2012, 09:47 AM
Nline6's Avatar
Nline6 Nline6 is offline
Always best in the NW
Mein Auto: E39 528it & E36 M3 sedan
I just installed some SC50s in the front, everything sounds good except I beleive one of the woofers is flawed from the factory as it seems to give me a little but of a crackle under heavy bass. The other speaker is fine. Hope the seller covers the defective product.
Touring the nation, one state at a time
Old 12-31-2012, 10:13 AM
Is the subwoofer or mid range woofer? If the latter, it might be that your cutoff frequency is too high.
Old 12-31-2012, 10:37 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
i have the Polk-Audio 5 1/4" components. These here, and the sound is good.
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 12-31-2012, 10:53 AM
The DB series Polk component speakers are pretty good, I upgraded mine with 6 1/2" Polk DB component (1" tweeter) in my Maxima few years ago and couldn't be happier.
Old 12-31-2012, 11:43 AM
Nline6's Avatar
I only get the crackle sound from one side of the car. When I transfer the balance to the drivers side the sound goes away and stays with the passenger side door woofer. How do I adjust the cutoff?
Old 12-31-2012, 01:40 PM
It depends on what you have, you can transfer balance from the head unit, but not cutoff point. The component speakers you bought should have a small box to be installed inside the door panel, that box is a cutoff circuit. The line from head unit feed one end of the box, and you wire two separate pairs of wires from the other end, one goes to tweeter and one goes to the mid-range woofer. The cutoff circuit will split the high frequency signals to tweeter and mid to low frequency signals to the woofer, and that splitting point is cutoff point and usually the cutoff point is manufacture preset (like 2k above goes to tweeter) and you may or may not be able to adjust cutoff point, that circuit may be bad. To be sure if your speaker is good, you can swap the speakers, if you still hear the crackle sound after swap, then it most likely the cutoff circuit is bad, if the crackle sound changed to the other side after swap, then it is the speaker's problem.
Old 12-31-2012, 08:45 PM
BadBrad BadBrad is offline
BadBrad
Mein Auto: 2003 540iA M-Sport
I believe that you can't go wrong with any of the major brands for a 5-1/4" component set. I would not use a set that has 2 ohm components though, because you don't know the amp in the head unit will react to that low an impedance. Personally, i put two sets of Boston Acoustics SC50 and two Rockford Fosgate R2SD4-10, 10" shallow mount DVC subs. But I have the DSP setup and am happy with the results.
Take a look here at a thread started by LimLev. He has a non-DSP setup and would be a good place for you to start.
