BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Navi on head-up display disappeared . . . help!
I've been playing with the various features and codes for the HUD on my 2013 M5. I made the coding changes per the cheat sheet v.3 to enable the entertainment list, telephone book, contacts list, voice commands, navi and turn signals ("blinkers") on the HUD. Coded both the HU_NBT and KOMBI modules. Worked just fine, until . . .
I played around with a few other codes (I didn't keep a log, shame on me) and now the blinkers and the navigation info no longer appear on the HUD. I confirmed that the relevant HU_NBT and KOMBI items are coded to activ, but still no luck. Note that the "Navigation" check box is checked in the Head-Up Display settings menu. The entertainment list, phone book and contacts all still appear on the HUD. BTW -- discovered a self-test feature for the HUD -- if you hold the head-up display button to the left of the steering wheel for >10 seconds it will cycle through various calibration screens with each subsequent press of the HUD button. Anyway, I don't care about the blinkers but I would like the Navi back. Any suggestions? |
Last ditch resort, but I'd default everything back and redo the changes you did to begin with. I just got finished coding as well.. Sounds like you tinkered with a lot more then I did though.
2013 BMW M5 Alpine White, Full Black Merino Leather, Anthracite Wood Trim, B&O, Executive and DA Packages, 20' Wheels |
Nice ride, BTW! Mine is Azurite Black Metallic. |
Connect => Read FA => Activate FA => Read VCM => Right-Click on KOMBI (the ECU itself not the underlying CAFD) => Select CODE. This is a VO Code of the ECU, which will reset it, and it is not the same as FDL Code or Code Defaults. Repeat the Process for HU_NBT module. This should return your HUD and iDrive to your as delivered condition.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 12-30-2012 at 07:15 AM. |
Shawn to the rescue (again)!!! Re-coding per your instructions did the trick.
Everything is working fine now, but I did get an error code in eSys when coding the KOMBI module. Should I investigate further or leave it alone? Again, everything appears to be working just fine. |
Umm...what is the error?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Not sure what the error was -- is there a log where I can look it up? I can also try to re-code the KOMBI and take a screen shot of what I get.
Note that I'm using the 48.1 pdz files (I upgraded per your instructions). |
If you have a current error, post a picture of it.
So what am I doing wrong? |
I deleted 47.5 and replaced with the full 48.1. Pretty sure I replaced with the PSdZData with the new one. How can I confirm?
Do you get this error only when you FDL Code KOMBI, or when you VO Code KOMBI too?
Please try again this morning, Connect, Read FA, Read VCM, and VO Code KOMBI.
One more thing -- there's a string after my VIN on the Open Connection dialog that reads "_DIAGADR10" -- what does this mean?
You mean on the bottom Connect via VIN? I think that is normal.
You need a Screen Capture Program. See this: http://www.picpick.org/en/ Ok, I have never seen a [C206] error, ever, and it bothers me. If it was my setup, I would blow it up, reinstall E-Sys and the 48.1 PSdZData from scratch. Something just isn't right.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
