1985 e30 325e unexplained surging idle - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 12-28-2012, 09:44 PM
whakin whakin is offline
Mein Auto: 1985 325e
Exclamation 1985 e30 325e unexplained surging idle
I have been through the threads all over online for months now..nothing has helped. I have an erratic surging idle, the idle varies from consistent high about 1200rpm's to surging from 500 to 1200 to surging from 800 to 1800 I've noticed about four different idle patterns now. It occurs approx 90% of the time, the other ten percent it idles about 1000. I replaced most vacuum tubing (all the others are ok, atleast seem to be), replaced the intake elbow. I cleaned and tested the ICV with a 12v source and it operates, I could not find any resistance specs on the two wire set-up ICV. I replaced the coolant temp sensor also. The car sometimes bucks when driving and at certain speeds like 45mph in fifth gear I do not need to touch the throttle, the car will just keep going due to this idle issue. This has me completely stumped. Any help is very much appreciated!
Old 12-28-2012, 11:51 PM
BMWFatherFigure's Avatar
Old School
If you have the 'linier' ICV they can get a dead part on the track. Check with a DMM while moving the valve over its full range.
Current:
E38 Parts Car
Previous:
Old 12-28-2012, 11:56 PM
It is the linear one with the two wire plug. DMM? Sorry probably a dumb question. And could I check resistance on it? I have no specs though :/
This seems to make sense though! It would be functioning but not correctly.
Old 12-29-2012, 10:28 AM
Old School
The test is to work the unit through its full range of movement while an ohm meter is connected. There should be a smooth even change in resistance. Any variation (ie a dead bit) will mean a new unit. Sorry I cannot give ohm value range but the dead bit is the give away.
Current:
E38 Parts Car
Previous:
Old 12-29-2012, 10:55 AM
Awesome! Thank you very much, hopefully this is the problem. I will reply back with my findings!
Old 12-29-2012, 11:15 AM
Ok, just ran the test and all along it's movement it remained a constant 8-9ohms of resistance. It averaged about 8.4 but never dropping below 8 or ranging above 9. I'm guessing that means the ICV is still good?
Old 12-29-2012, 12:33 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
DMM= Digital Multi-Meter
You should have had a range of readings from full closed to full open. An unchanging reading of 8-ish ohms indicates the ICV is dead.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-29-2012, 02:01 PM
Alright sounds good! Does anyone know of a good place to buy these from? Everywhere I look they're about $200...little pricey
Old 12-29-2012, 04:04 PM
D'oh, You Kids!
Rockauto has them for about $170. You could always get one from a wrecking yard but reliability could be questionable.
Quotes to live by:
BMW-CCA #441426
Old 10-21-2014, 05:14 PM
austinw49 austinw49 is offline
Mein Auto: 85 325e
Did you ever find out what was wrong? Because my 85 325e is doing the same thing but sometimes it just cranks.
Old 10-22-2014, 01:16 AM
Old School
Totally differnt set of problems. Best start your own thread (if you have tried all the fixes you find). We need full symptoms ( and when / how they occur) to really help..
Current:
E38 Parts Car
Previous:
