E30 (1982 - 1993)
Old 12-28-2012, 11:14 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
Carpet wet by drivers foot pedal (rhd)
My right hand drive e30?has damp carpet in the drivers footwell area but the elephant trunk is clear .. What else could be causing this?
Old 12-29-2012, 12:44 AM
BMWFatherFigure's Avatar
Old School
Rain. Windscreen leaks. Heater leaks. Rusted floor. Door drain holes blocked.
Current:
E38 Parts Car
Previous:
Old 12-29-2012, 01:41 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
most likely leaking heater matrix, check your coolant level will confirm
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 12-29-2012, 02:37 AM
Im back again. Not thrilled at the water leak :/ but at least I know where it is coming from. Didin't take more pictures because I did not think it was that significant, but I will describe it as best as I can.
Car smelt damp after rain. I felt dampness by the foot rest (next to the clutch) and thought it was the well known elephant trunk. I have rubber floor mats never bothered to really check under them. Removed carpet and underside was fairly damp, like the whole floor pan area. Luckily no rust.
Put hose on outside with carpet removed and saw water dripping from this..(it is the rubber grommet for the air con lines).
After about 1.5 minutes with the hose on the outside there was a 1/2 piece of bread sized puddle on the floor pan.. no wonder the carpet was soaked. Hate to think what it is like after a few hours of rain
Why was water getting on the rubber gromet for the aircon lines anyway that is in the engine bay.. lifted the bonnet, battery tray had a great puddle.
Part of the problem is a worn bonnet lip seal that runs along below the windshield.
But the main problem is a little bit of suspected rust which lets water drip through where the front wheel arch panel joins the car. It drips through to the battery area. Also any water entering the air vents by the window wipers must be going through another bit of rust. They both drip through by the bit where the bonnet slots in near the battery, directly above the grommet for the air con lines.
I have a little bit of work to do..
Old 12-29-2012, 06:11 AM
Old School
Sorry about the rust. Never cheap or easy to fix properly.
Current:
E38 Parts Car
Previous:
Old 01-01-2013, 04:35 PM
Ok im trying to work out why exactly this is happening. On second look water does not seem to drip on the air con line grommet when it enters the vent by the window wiper. I thought it was the other day when I had the hose but just tried with my drink bottle. So maybe it was just a bit running onto where the front fender attaches to the car.
If water hits the seam where the fender is bolted it drips through underneath where the bonnet bracket is and onto the grommet for the air con lines but why. It looks like a previous owner had had this too because there is a bit of glue on the seam but it wasn't glued from factory was it? so why is it dripping through. It is hard to photograph up under the bonnet bracket obviously but i looked with a mirror and torch and it does not look like it is dripping through rust it drips off this small edge of metal.
if water goes over this seam it drips through
notice the air con line grommet and rust. But the drips dont come from the rust they come from up under the small box shaped bracket the bonnet holder is bolted into
Old 01-02-2013, 02:56 AM
I removed the plastic cover inside the wheel arch and found this..
Getting rid of that must help the drainage situation, flip I spray the hose under the arches each time I clean it so I thought my car was clean. Must be about 1.5 kg worth of dirt which was so neatly compacted up behind the plastic it looked like part of the car.. until I stuck the screw driver into it. I am going to remove the fender just to have a good look and be sure .. I hope things don't get too bad in terms of rust discovery
The plus side is after I clean out the wheel arch on the other side my car will be about 3kg lighter
Old 01-06-2013, 02:13 AM
So I found where it is leaking in and at the moment I am cleaning the area up. Took the fender off and everything else looks fine no nasty surprises. Photo is by the battery by the way.
Although I am a bit noob in the area. How should I repair it? The metal is lifted slightly due to rust where the arrow is pointing. Should break the tack welds bend it up and remove rust underneath? the only thing is I don't know how to weld.
Or should I just paint rust killer on the area?
Old 01-06-2013, 02:37 AM
Old School
The more you spend getting rid of the rust the less likely it is to come back. Good/fast/cheap - ring any bells? Find a good body shop and bite the bullet.
Current:
E38 Parts Car
Previous:
