Old 12-29-2012, 09:52 AM
firehawk17 firehawk17 is offline
Mein Auto: 97 528i
aftermath of starter replacement
whats up fellas... so after the grueling experience of replacing my starter on my 97 528i via moving the manifold out of the way not completely off... after putting everything back started the car fine... when i cut the car off i hear the sound of air escaping.. I went back over it. I didnt take off many vacuum lines but what could it possibly be? any ideas thanks
Old 12-29-2012, 10:16 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Did you have to take out the oil dipstick tube to get the starter out?
I think this is only done if you decided to take the starter out from
below the car. If so, then perhaps the seal on the dipstick tube isn't sitting flush.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 12-29-2012, 10:25 AM
Mein Auto: 97 528i
yes i did have to remove the dipstick... but i put it back flush.. is there a seal on the tube?
Old 12-29-2012, 10:52 AM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
Yes, the oil dipstick tube has a seal.
BMW part number 11 43 1 740 045
Old 12-29-2012, 11:08 AM
Mein Auto: 97 528i
yea when i put it back i didnt see a seal on the tube.. just seen the tube i put it back in flush.. what does the seal look? any pic of it?
Old 12-29-2012, 11:16 AM
Dave @nz Dave @nz is offline
Mein Auto: E36 323 Msport, & E30 M3
Hi,
What you hear may well be normal sound of air moving through the throttle butterfly when the engine stops, I would be having a good listen with the engine running may be use a piece of plastic hose against your ear and other end put along the manifold area to try and id any areas of concern.
Dave.
Old 12-29-2012, 11:24 AM
Mein Auto: 97 528i
thats about the area that i hear it.. but i don't recall hearing that before hand... i could be hyper sensitive to noises after putting everything back.. not wanting to screw up
Old 12-29-2012, 11:53 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
The PCV hose is attached to the dipstick housing.
Old 12-29-2012, 12:01 PM
Mein Auto: 97 528i
i have that attached...
Old 12-29-2012, 09:21 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
See pictures of the seal over here:
- How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 12-29-2012, 09:32 PM
Mein Auto: 97 528i
is that the title of the post on this forum?
Old 12-29-2012, 10:11 PM
bluebee's Avatar
Ah, you're new here.
See the little (1) at the end of the reference.
It's like a biology paper in high school. It's a reference mark.
Only this one is clickable.
I found it for you simply by typing /dipstick F3 in the bestlinks.
More details here:
- How To Easily Find Information on Your E39 Topic Before Posting a New Thread
