E90/E91/E92/E93 (2006 - 2013)
Old 04-15-2013, 09:49 AM
jrg64 jrg64 is offline
Mein Auto: 2011 X5d, 2007 335i Conv
just purchased used 2007 335i convert
Hello all-
My wife and i just purchsed a used 2007 335i convert with 47k miles the dealer didn't have any service records so we are looking a potential laundry list of items that shoudl be looked at, are there any items that i may be missing? Any help would be great.
1. Spark Plug Service light, I assume the spark plugs have never been changed
2. Brake fluid flush?
3. Coolant System flush?
4. Automatic Trans flush?
5. Rear Differential
6. Cabin Air filter
Old 04-15-2013, 12:01 PM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Originally Posted by jrg64 View Post
Hello all-
6. Cabin Air filter
NO service records? You checked a genuine BMW dealer?
If really no records, you should find the fish that's creating that smell around your car!
Old 04-15-2013, 12:05 PM
nothing besides the standard oil changes and vehicle checks
Old 04-15-2013, 06:54 PM
fun2drive's Avatar
BMWCCA 149159
You have a complex retractable hardtop. I would strongly suggest putting a suitable rubber treatment like Gummi Pfledge on all seals. I would also suggest lubricating all hinge points for the top as well. See the sticky on perserving your top at the beginning of this section. Also at 47K miles I would do a drain of the AFT in this case LifeGuard 6 or Mercon SP and refill.
Mercon SP can be sourced at O'Reilly's and the LG6 at this location for the best price (that I know of anyway)
http://www.thectsc.com/index.php?p=p...id=10&parent=0
Yes I would guess plugs need replaced and a good idea to do the coolant flush and diff change as well as a brake flush.
I am sure you are aware that intake valves will need cleaned and that the water pump will fail most likely in the next 20K miles or so. I keep a new water pump and tstat in my trunk just in case as I have 58K miles.
Welcome from one vert driver to another...
Old 04-15-2013, 07:16 PM
Mein Auto: 2007 335i
Nice car. The only other thing I can think of is the serpentine belt, but I don't think they recommend changing that until 60K. I understand that some early e90s had issues with the belt rubbing and breaking prematurely so it might be a good idea to inspect it.
94 318i, 97 528i, 07 335i
Old 04-16-2013, 01:15 PM
fun2drive's Avatar
BMWCCA 149159
My car is a 3/2007 build date and never had any issue with the serp belt but that might be just luck.
Great car by the way looks excellent...
