2007 X5 Problem - Bimmerfest - BMW Forums
Old 12-29-2012, 02:47 PM
Kparmar Kparmar is offline
Mein Auto: 2007 X5, 2006 525i
2007 X5 Problem
Hi guys, I was trying to find more insight into what might be causing my X5 to have some issues.
Lately, the cars been giving me trouble when it comes to starting it up. And the Idrive system will give me errors like: 4x4, DSC,... failed and wont start up.
But if I get a jump from another car it starts up fine. Also keep in mind it does start up normally for a few days then just dies out again. I had the battery replaced roughly a year ago but didn't see this problem until a few weeks ago.
Thanks for your help
**also if there is a post about this problem from the past I apologize but if someone could lead me into the right direction it would help**
Last edited by Kparmar; 12-29-2012 at 02:48 PM. Reason: for people to let me know if this problem has come up in the past
Old 12-29-2012, 04:58 PM
ChuckGr ChuckGr is offline
Mein Auto: X5 35D
You need a new battery. A bad battery will give those errors.
Chuck
Old 12-31-2012, 09:28 AM
onebadgix onebadgix is offline
Mein Auto: 2009 x5
Or at least take the battery back to where you bought it and have them run a load test on it. If it can hold a load, then maybe your alternator is not charging it up properly and it needs to be replaced.
Old 12-31-2012, 09:53 AM
ard ard is online now
Resident Curmudgeon
Original battery???? GET A NEW BATTERY
Do no screw around with testing the battery on the bench or on the car.
My opinion
A
Old 12-31-2012, 01:24 PM
Hey, Thanks for all your help
Im going to take it back to the dealer I bought the battery from since I think it still holds its 1 year warranty.
The battery is new it was replaced about 8 to 10 months ago
The thing I dont understand is why would the battery randomly start to fail after about 8 months.
If it is the alternator do you guys know much it usually cost to replace it?
Old 02-07-2014, 06:30 PM
Jon_B_X5 Jon_B_X5 is offline
Mein Auto: 2007 X5 4.8
Hey, did you get this fixed? I'm having the same exact issue. Please let me know. Thanks!!
Old 02-17-2014, 08:50 PM
ADeCArolis ADeCArolis is offline
Mein Auto: 2010 E63 M6, 2013 E70 X5
Buddy had this problem with the same year. He said the battery kept draining and the engine light would turn on. Needed to replace positive battery terminal/lead... cost 1k he said.
