E36 (1991 - 1999)
Old 12-29-2012, 05:03 PM
bmw_novice bmw_novice is offline
Mein Auto: E36 328is
Inexpensive Suspension Refresh - Front and Rear
My project for the 97 328i for the new year includes a suspension refresh - what is required and what is the least pricey option? Yes, I am being a bit cheap but then, $$s are tight as of now. Here is what I am looking to do:
Front Axle:
Struts
stabilizer bar bushings
Stabilizer bar endlinks
control arm outer bushings
Driver side sway bar bracket mounting has corroded, will be welded on, just got the part from pelican.
Just did tierods 2 months ago.
What else would be needed here? Ball joints?
Rear:
Note: I hear/feel the bump pretty well in the rear, however, there is no slippery feel as it was before doing the RTABs.
Did RTABs in february, thing is, I didn't know then that there are upper and lower RTABs, God knows how much was done. Last time a mechanic looked at it, they did not suggest anything needs replacement. But I can certainly feel the bumps - shocks?
Stabilizer bar bushings
Stabilizer bar links.
Shocks and Springs (one spring is broken I believe).
What else needs to be replaced? Anyone knows? What kind of $$s am I looking at if I get all the above done
Blast that damned starter!
Old 12-29-2012, 05:59 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
ball joints are part of the lower control arms. you will need front control arm bushings.
as for inexpensive, good luck with that. cheapy parts tend to give poor performance, and wear out quickly.
rear shock mounts with reinforcements should be used. i like rogue engineering, but have turner aluminum mounts in cadence.
the ti will most likely get the rogue units.
probably your best bet would be to buy an entire supension kit, and even though you have new parts, get them. you could always try to resell them.
df
Old 12-29-2012, 06:06 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
What is your total budget?
1998 BMW 328is
1966 Pontiac GTO
Old 12-29-2012, 06:28 PM
jmo69 jmo69 is offline
Mein Auto: 98 328is 2003 325xi
Check out FCPEuro, they have kits that can save you some$$$. Contact Gareth Foley and he'll give you a discount for being a forum member. At least he will for Bimmerforum members. http://www.fcpeuro.com/
98 328is Cosmos Schwarz Metallic 55w 6000K HID w/angel eyes smoked headlights, tails, corners, fogs and side markers Sparco strut brace, X-brace, Eibach Pro Kit springs, CAI, Prosport gauges, LEDs where ever they work, DDM pedals, 35% tint all round, HD lip, M3 style rear diffuser.
Old 12-29-2012, 08:18 PM
Budget ~ 1000 parts + labor that is, I'll be pushing the envelope since I have to get that damned starter replaced as well! DF, I realize cheap parts are not a good idea, but alas, I am a poor man trying to maintain an older Bimmer.
Old 12-29-2012, 08:51 PM
ZeGerman's Avatar
Warm Leatherette
You should be able to get it done for that amount. My recommendation for shocks & struts for an E36 which won't see track/auto-x are the Koni STR.T line. They're the cheapest that Koni makes, but they're still very high quality and have a lifetime warranty.
Whatever you do, I definitely do not recommend buying cheap control arms. They will fail prematurely, and you'll end up paying more in the long run than if you had just bought the best (Lemforder). Keep in mind, every time you replace the control arms, tie rods, FCABs, etc., you have to get an alignment performed, and those usually run about $80-100.
As far as where to buy from, FCP Euro often has good prices. I've been using GetBMWParts.com lately. They also have good prices and low shipping rates.
1998 BMW 328is
1966 Pontiac GTO
Old 12-30-2012, 06:51 PM
OrionsGate's Avatar
OrionsGate OrionsGate is offline
Forever Nerd!!
Mein Auto: 1995 325i
Spring for the Powerflex PU bushings for the front sway bar & control arm lollypop. Rear shock mount reinforcements from Rogue are a must (drivinfaster is absolutely correct). And, you should be able to find a set of H&R sport springs on Craigslist.
1995 325i, 235K miles (yes!), 5sp, LSD, M3 cat back, halo projectors, H&R/Bilstein/etc. suspension overhaul, painted sideskirts...Oh now it's white...plasti-dip... snap.
Old 12-31-2012, 09:50 AM
the fly the fly is offline
Mein Auto: '06 750i, '01 M3 vert
In case it helps, I am selling new M3 rubber pre-pressed into housings -- centered or offset -- for $75 shipped. Makes the swap easier...
http://www.bimmerfest.com/forums/sho...806&highlight=
M3 solid rubber bushings are a bit firmer than non-M (with the holes) but not quite as harsh as poly...
Old 01-04-2013, 12:14 PM
^ Thanks mate, I am not sure I can do the front as yet.
By the way, I have one broken spring (left rear), how do I fix this? THought of getting another set of springs but they are expensive and normally tend to come in sets of 4. I just need to do the rear. The 97 328i that I have does have the sport package so what rear springs will fit? Are the EBay ones such as JDM any good? Is there a way to get used springs? Any thoughts?
Old 01-04-2013, 02:05 PM
Some more questions:
1) Is it OK to do rear springs + shocks without doing the fronts? Or do I HAVE to do them together?
2) Can I use Bilstein Touring Shocks with H & R OE Sport Springs?
The current set up is a stock BMW 328i with the M-tech suspension (I confirmed this with a dealership as well as the online bmwvin decoder)
Old 01-04-2013, 02:29 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
1. Yes, they can be done separate. Just do each axle together.
2. If you use sport springs, you MUST use sport shocks, else you will prematurely fail the shocks.
Try taking a look for Koni str.t shocks. Great value, and low enough for sport springs.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-04-2013, 03:27 PM
Thanks Jonesin, I am looking at the Koni STR.Ts @ about $ 80 per shock , the Sachs for about $ 140 for two, bilstein HDs (black) @ $ 65 for 1 (but they are supposedly quite harsh, and I am not much for that. Just want a smooth + tight ride. I have been driving a grocery sedan all my life so far (Ford Taurus) and that too with not very good shocks. So anything will be an improvement.
Will the H&R or Eibach spring set work with the sachs set? Also, is there no other inexpensive alternative to a broken spring than a 4 piece sprink kit such as Eibach or H&R? Thanks for your time.
Old 01-04-2013, 03:32 PM
ZeGerman's Avatar
Warm Leatherette
If you just want to replace your springs, get on Craigslist and pick up a used set for next to nothing. You shouldn't have to spend more than $50 for a set of used non-M sport package springs.
1998 BMW 328is
1966 Pontiac GTO
Old 01-04-2013, 04:15 PM
^ I thought I would need m technic specific springs for this car since it has that suspension and since those are insanely expensive and difficult to get, thought I would need a set of springs as well. BUT, if I can just make do with any other e36 spring set (will an M series also work?), that'll really help pull the cost down since the cheapest springs I can find are these:
http://www.ajusa.com/KONI-1020-6021-...gs-a1cea9.html
And I don't know if those will work for the M-technic spec either as the sticker states. Btw, my rear tires are 225/16/55 - will there be a problem if I HAVE to get aftermarket springs say Eibach Prokit?
At this point, I am pretty satisfied with my car's ride height and all, just want to get a better ride. Btw, a local chap is fixing the starter motor with an aftermarket (New) piece for $ 270 - thought this is a good deal.
So what else will i need with the rear shocks and springs? Bumpstops, Shock mounts and reinforcement plates. Anything else?
WIll also do swaybar links + bushings. That is all I can afford for now. And may be if I get lucky get that damned front swaybar bracket mount welded on as well.
Old 01-05-2013, 05:47 PM
Hello again gentlemen,
So, can I use any e36 model springs for the rear on my 328i w the m tech sport suspension? Let us say Joni sport str.ts or Sachs w a set of springs from an m3 or 325? Please let me know, gracias
uss
Old 01-06-2013, 02:21 PM
Hello? Anybody?
Old 01-06-2013, 02:22 PM
jonesin's Avatar
The Canadian Prick.
You must match lowering springs to lowered shocks/struts.
If going OEM height, then use OEM height.
Old 01-06-2013, 02:43 PM
THanks Jonesin, however, my confusion is about what German pointed out - that I could replace the springs with used ones from Craigslist/ebay - can these be from any e36 (non - M3)? And then how do I know what type of shocks to get since the OEM set up is slightly different for the 328i M tech suspension? Take these for example:
http://www.ebay.com/itm/170969307179
will they work? If so, what sort of shocks should I be using - sport or non sport?
Do let me know, and my apologies for being so dense - am totally new to this stuff.
Old 01-06-2013, 02:49 PM
jonesin's Avatar
The Canadian Prick.
Give this a read, it'll go into more detail than I can on my phone.
http://jj100d.blogspot.ca/2011/03/e3...ike-legos.html
Old 01-06-2013, 03:05 PM
THanks, just went through the above linked write up - not that I could understand it much, but this worried me a bit:
To upgrade the suspension on one of these early cars, you need to do the whole package including sta-bars (due to the width of the stock bar relative to the control arm mounting locations), but that package can be intended for any E36.
I assume this is only applicable to the early e36s and since mine is a 97, should be OK to get springs from another e36 (non m) and stick them in there irrespective of the m-technic suspension. Since, also from above:
First, be aware that all E36 coupes and sedans have the same chassis mounting points.
But then, I might have completely misunderstood the writeup. Can you tell me if I can use the ebay springs I quoted in my previous post with a particular shock such as Koni (non sport) or the Sachs non sport or the biltstein tourings?
Old 01-11-2013, 12:41 PM
Hello Again,
Would someone please help me out - can I use non m technic/sport e36 springs for the Bmw e36 328i with the mtechnic suspension, if so, what particular type of shocks should I use to go with these? sport or non sport.
Old 01-11-2013, 02:24 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I wouldn't advise it.
Honestly I'd just save money until I could afford a complete set and not mismatch. Suspension is a large factor in safety with a vehicle. Braking, turning, general grip of the road all depend on proper suspension. Compromise could be dangerous...
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-11-2013, 05:23 PM
ZeGerman's Avatar
Warm Leatherette
Just out of curiosity, what are the last seven digits of your VIN? I'm curious to see if your car actually came with M-Tech springs in the first place.
1998 BMW 328is
1966 Pontiac GTO
Old 01-11-2013, 06:32 PM
I think you misunderstood me Petriej, I don't plan to mix and match. I am just wondering how I can replace the rear springs as one of them has broken. Since I need to replace the pair, would it be an issue if I chose to go with another e36 set (Non m technic) with just normal (non sport) shocks?
An indy shop I go to in Indy (ha ha), suggested replacing the rears with E30 springs - said it would not be any issue! At least I am still thinking of replacing with non m technic e36 springs.
Old 01-11-2013, 06:38 PM
YOu have PM. A nearby dealer did confirm this, so did an online decoder. But who knows. I can see an M technic spring (only 1) on ebay from a 318ti. Will this work for the left rear spring, which is broken?
There are quite a few M3 rear springs for sale as well (H&R), would these work if I replaced the set? I read somewhere that using this would entail replacing a lot more than just springs and shocks though.
OR
Can i just buy a non m tech e36 spring set and hook it up with non sport shocks?
Thanks.
