Old 12-30-2012, 12:45 AM
chenlwang chenlwang is offline
Mein Auto: 530i
Exclamation Peake code 19 96
My 2001 E39 SES light on, peake code is 19 96. I change two pre-cat O2 sensors and clear fault code. Start engine and drive for a while, no SES light on. But after turn off engine and start engine again the SES light come back and same 19 96 code. Please help
Old 01-01-2013, 11:17 AM
Mein Auto: 530i
Hello, anyone can help?
Old 01-01-2013, 11:50 AM
energizedmortal's Avatar
energizedmortal energizedmortal is offline
Mein Auto: 2003 530i
Here are a list of OBD II codes
http://www.obd-codes.com/trouble_codes/bmw/
List of OBD I codes:
http://www.bimmerwerkz.com/forum/3-s...des-54752.html
Inspect o2 sensor wiring...A friend with a e46 had o2 sensor codes because mice chewed the wiring.
Old 01-01-2013, 01:02 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Please provide the text description of the code.
Also, what symptoms are you observing?
Old 01-01-2013, 01:32 PM
Fudman's Avatar
Fudman Fudman is offline
19 96 is "Precat O2 sensor voltage, cyl #1-#3". It's not the sensor since you changed it. I would inspect the O2 cable for some damage (mice?).
Old 01-01-2013, 06:20 PM
Mein Auto: 530i
Thanks a lot,
The front one is cyl #1-#3 sensor? or the back one (close to passenger side).
Car runs ok, just a little shaking when warm up in the morning.
Old 01-01-2013, 07:01 PM
Fudman's Avatar
The cylinders are numbered 1, 2, 3, etc. from the front.
Old 01-01-2013, 08:13 PM
Mein Auto: 530i
Where I can find O2 sensor cable parts number from realoem.com?
Old 01-02-2013, 10:16 PM
Mein Auto: 530i
Any one know pre cat o2 sensor cable part number ? I can not find it in realoem.com
Old 01-02-2013, 11:28 PM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
There are no o2 cable, it is just the sensor with the cable as a unit.
