Old 01-18-2013, 01:04 AM
gambet55 gambet55 is offline
Mein Auto: 528xi
In the Red
The bimmer I'm work on sitting at idle, will get into the red fairly quickly. The fan does not engage at all, and is getting power thus was replaced. The Thermostat has been replaced as well. Any Suggestions
Old 01-18-2013, 01:16 AM
Reuvers Reuvers is offline
Mein Auto: BMW e39 540i '97
was it bled properly? could be air
Old 01-18-2013, 10:43 AM
CMRTN CMRTN is offline
Speed Racer
Mein Auto: 98' 540i/6
fan clutch
TRUELY OEM.
Old 01-18-2013, 11:34 AM
uncmozo uncmozo is offline
Mein Auto: 2002 530i 5 speed
Water pump? Old plastic impellers break down over time.
1995 525i 5 speed - sold at 225,000 miles
2002 530i 5 speed - 187,000 miles
Old 01-19-2013, 12:07 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
Fan clutch
Old 01-19-2013, 07:37 AM
Fudman's Avatar
Fudman Fudman is offline
Your post is a bit unclear. Which fan does not engage at all? Which fan was replaced? Does the aux fan ever come on when overheating? The primary cooling fan is activated by the fan clutch (belt driven). That should engage or disengage depending on engine temp. It usually only operates during low speed/stop & go driving when there is insufficient airflow through the radiator. The aux fan (electric driven) only comes on when the primary fan is not moving sufficient airflow. Check your fan clutch first. Do the rolled paper test. Then check your aux fan.
See Issue #1 for fan diagnosis: http://blog.bavauto.com/12247/bmw-an...ostics-how-to/
