Old 12-30-2012, 11:08 AM
jordon jordon is offline
Mein Auto: E39 M5, E60 530i
need hose diagrams for m62tu
Hey guys, so my fan exploded a couple days ago (grrrrrrrr) and destroyed my hood, and cut a bunch of lines in the front. I could really use a diagram of the hoses up front so I can order all the right parts asap so I can fix it. Almost every line possible is cut (including one going to the oil filter housing). thanks in advance!
Old 12-30-2012, 04:19 PM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
Go here:
http://www.penskeparts.com/fiche.aspx
or here:
http://www.realoem.com/bmw/
You will need the last 7 numbers of your Vin#. You will not only get the part numbers you need, but will also see a diagram of the hoses, etc. Be aware that the diagrams are generic and sometimes not very accurate.
Old 12-30-2012, 05:08 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
http://realoem.com/bmw/partgrp.do?mo...3&mospid=47588
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 12-30-2012, 07:19 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
There are at least three different reasons WHY a fan would just 'explode' on you ... so it behooves you to figure out which one it was.
The bestlinks will be your friend in that quest.
See also:
- Pictorial look at typical E39 cooling system failure modes (1)
Old 12-31-2012, 05:37 AM
See also:
that's not what I asked, is it?
Possible reasons: 1) I already figured that out 2) first priority is getting my daily driver back in running condition
I am sure that your heart is in the right place, but honestly, I am also quite sure that you are neurotic and obsessive compulsive (often bumping years old dead threads to add a post with 60 semi (ir)relevant links)
Thanks to the earlier posters, I appreciate the relevant (and helpful) links.
