Old 12-30-2012, 02:10 PM
vegas645 vegas645 is offline
Mein Auto: 2005 645ci convertible
Unknown leak
I noticed this when I did an inspection of the engine. The location is on the passenger side below the engine.
Any ideas? There are no warning lights.
Old 12-30-2012, 02:13 PM
More pics
Old 12-30-2012, 03:21 PM
HerbP HerbP is online now
The picture is hard to make out, but it looks like a valve cover is leaking.
Old 12-30-2012, 03:34 PM
When I first start the car in the morning, it idles sporadic for about 5 mins. Then it is at the normal idle. If I don't let it run for 5 mins then when I drive on the freeway, it almost feels like it is going to cut off but there is a noticeable up and down drag on the accelleration. When I get home, it has a smell of burning oil.
Could it be a vacuum pump leak?
Estimated cost I should expect if it either of these problems?
Old 12-30-2012, 05:28 PM
There are 4 things that I think of that might leak on the passenger side. The valve cover or timing cover seal, the oil pressure sensor, the vacuum pump, or that the P/S reservoir is over filled. I would spray a can of engine gunk on the engine, then hose it down good. After this look at the engine every day, until you see where it is coming from. Looking at your pic, the valve cover gasket would be my 1st guess. The rubber seals at the bolts seem to leak, if they are not torqued properly.
Good Luck
Old 12-31-2012, 06:54 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
+1 on the engine clean as that looks like very old oil, and see from there????
Always said I would go back to a 6 series
