Old 12-30-2012, 09:31 AM
esoes06 esoes06 is offline
Mein Auto: E39 528i
current fuel consumption problems 528i
current fuel consumption 120km/h Pressing the accelerator pedal fully tachometer current fuel consumption max 14liter and acceleration problems
Pressing the accelerator pedal fully 5gear tachometer 12 and 14 liter and do not have any acceleration
What is the problem
Old 12-30-2012, 11:10 AM
Mikes530 Mikes530 is offline
Mein Auto: 530
Sorry but this is really difficult to understand due to the language barrier.
I can understand that you have poor acceleration but do you mean that you are getting 14L /100km at 120km/h? Or does you mean you have an average of 14L/100km and your car will not go faster than 120km/hr?
Old 12-30-2012, 11:30 AM
Mein Auto: E39 528i
yes poor acceleration
help me
Old 12-30-2012, 11:41 AM
Dackelone Dackelone is offline
Mein Auto: 540i v8 manual
Have you check for engine codes? ODB-II codes.
Might be your MAF (Mass Airflow Sensor). You could unplug it and see IF the engine runs better. They do go bad. Air filter Ok? Spark plugs, ect?
Old 12-30-2012, 11:50 AM
Mein Auto: E39 528i
changing parts
air flow meter
crank sensor
camshaft sensor
spark plugs
ignition coils
lambda sensors
dme ecu
transmission repair
150 6-cylinder compressor engine test compressor
petrol pump
injector
petrol filter
oil and filter changed
air Filter
results failed shovel up money
Old 12-30-2012, 12:11 PM
Does your car have a catalytic converter ? Maybe it is plugged up?
Old 12-30-2012, 02:50 PM
bmwtech6367 bmwtech6367 is offline
Mein Auto: 2000 528I
From what I can see in your video, you have the transmission in the Manual mode, which means the trans won't downshift if you press the gas pedal to the floor. This will give you bad acceleration. Leave the transmission in Automatic mode...
