Old 12-30-2012, 06:26 PM
ddoran ddoran is offline
Mein Auto: bmw 3 series convertible
2012 x5 with no heat
just drove home form patriots win over miami
temp outside is 16F
no heat comes out and then after 10 minutes driving a warning came on that engine temp is high and drive moderately
any idea what this is???????????????????????????????
x5 is 12 months old
thanks for any help
dd
Old 12-30-2012, 06:33 PM
tribecaX5 tribecaX5 is offline
Mein Auto: '11 X5 35d
Did you check the coolant level?
ihumphrey ihumphrey is offline
Mein Auto: 2011 535ix and 2011 X5
temp outside is 16F
x5 is 12 months old
thanks for any help
dd
Water pump? No actual idea, just guessing...
Old 12-30-2012, 06:49 PM
nothign checked yet
havent been getting heat for 1 week but tonight was first time i had a warning light
engine should not have been hot from only 5 minutes of driving in 16 degree weather
Old 12-30-2012, 06:50 PM
just had 1 years service
just sent in x5 for yearly service
wonder if they messed something up
dd
Old 12-30-2012, 08:27 PM
digdesign digdesign is offline
Mein Auto: 2008 4.8i
+1 Sounds like a loss of coolant.
- Mick D.
Old 12-30-2012, 08:58 PM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
Yeah, its freezing in Boston today. Thank god for heated seats and steering wheel
Old 12-30-2012, 09:40 PM
ard ard is offline
Resident Curmudgeon
temp outside is 16F
x5 is 12 months old
thanks for any help
dd
Water pump failure? When this happens the engine can heat VERY, VERY fast. Within a minute you can go from "ok" to "dead engine".
Once water stops circulating, the small volume within the engine overheats. Not getting circulation out of the engine to your heater core explains the lack of heat.
Did you stop driving????? You need to get it to the dealer.
A
PS What does 'patriots win over miami' have to do with the car?
Old 12-31-2012, 06:59 AM
thanks
called dealer
dealer wants to be safe, so tow truck on the way
Old 12-31-2012, 10:04 AM
arrivederci arrivederci is offline
Mein Auto: X5d
No heat for a week and you are still driving it?
Old 12-31-2012, 10:12 AM
onebadgix onebadgix is offline
Mein Auto: 2009 x5
Definitely take it back to the dealer. Sounds like someone didn't screw something on tightly. You never smelled or noticed any coolant leaking?
Old 01-02-2013, 01:15 PM
electronic control failure
dealer tested it and believes that electronic control failed
but not 100% sure so they are doing test drive
we shall see
no smell nor sign of coolant leak
had 1 year/15k service only 1 month ago
Old 01-03-2013, 12:13 PM
dealer replaced water pump but still has engine warning
warning light for overheating still coming on after few minutes of driving
dealer replaced water pump but it hasnt stopped the warnings from coming back on
any suggestions????????????????
thanks!!!
dd
Old 01-03-2013, 12:20 PM
NoI4plz NoI4plz is offline
Mein Auto: A box with 4 circles
Not a mechanic nor a engineer here so my advice; take with a huge truck load of salt.
A) do you have sufficient coolant after you get the warning. If not, maybe a pinhole leak somewhere
B) It may be as simple as you need to burp the radiator, cause you may have air in your system. Their is a published DIY on how to bleed air from the system on either xoutpost or on here. Search is your friend.
Couple of options WHO KNOWS!.
Hope you get it fixed asap!
BMW and Mercedes Build Beta Products!
Lexus build Release Candidate Products!
Why does this matter?
CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world!
Old 01-03-2013, 12:29 PM
2 interesting ideas
sometimes the simplest approach is the best
we had a cnc machining center that had 10 repair guys look at it when it went down
someone then came from the japanese mfg company, looked at it, clicked a switch in the opposite direction and repaired it in 10 seconds!!!!!!!
