Old 01-01-2013, 08:16 AM
upandown upandown is offline
Mein Auto: '06 325 - '82 Porsche 911
Quandry at 92k
5 speed 325. It's been a wonderful car...now the 'but.'
Two weeks ago, the car would not start due to a failed valve adjustment motor in the engine.
$2500.
Last week...my daughter wrecked 3rd gear with a bad shift. It grinds and chirps.
Have yet to install a used (87k mi) transmission and clutch.
Estimate is $3100.
Valve cover is fine.
What is down the road for me if I keep this car another three years at 18-thousand miles annually? Any thoughts? Estimated annual repairs?
I hate to lease something like and Acura TSX, but it's cheap, more practical, ....and I do own a 911 to feel the wild side.
Thank-you.
Old 01-01-2013, 09:35 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
$2500.
Estimate is $3100.
What is down the road for me if I keep this car another three years at 18-thousand miles annually? Any thoughts? Estimated annual repairs?.
Naturally, you've seen Bill Arnold BMW in San Rafael. Much preferred over having to deal with local dealer's pricing and SA's.
Alternative: DIY valvetronic motor replacement & transmission R&R. Makes ownership so much more satisfying. Bentley, of course.
Old 01-01-2013, 11:56 AM
floydarogers's Avatar
Pedant and Curmudgeon
Pretty sure you have a 6 speed...
The Valvetronic motor replacement should not have cost $2500.
$3100 for a used transmission and R&R; ok, but probably can be done for less. You might consider going to a normal transmission repair shop that does Getrag trannies; repair is not a hard job (I would not do this for an automatic.) You might consider replacing the clutch plate, disk and throw-out bearing (although they seem to last for 150K+ if not thrashed).
I would keep it - the car is worth $10K-15K if the work is done, and should really have anything else go wrong.
www.bimrs.org, www.bimmershops.com for non-dealer repairs.
Old 01-06-2013, 08:33 PM
Update
Yes...a 6 speed. '5' was a typo. The car is gone. It appears to have found a good new home. And yes, I did speak with Bill Arnold. He seems to be a great guy, but quoted 61-hundred dollars for a new trans and clutch. Add the need for a new battery, brakes, a tune-up, tires in 10k miles, and whatever else, and I purchased a Volkswagen CC. It's not quite a bimmer...but not a bad drive at all for daily commuting. Kinda like it, actually.
See y'all in three years or so, when the daughter graduates college, I retire, and buy that last car.
Thanks for the advice.
Old 01-06-2013, 08:46 PM
tturedraider's Avatar
Freedom isn't free!!
.....I retire, and buy that last car.
I hope that means you're gonna be 90 y.o. when you retire and you're not planning to have your last car for 20 or 30 years.
www.bmwcca.org
Old 01-07-2013, 02:28 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Now, I didn't do this, but a friend commented that when the last one graduates college, it's time to buy your first motorcycle.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
