Old 12-30-2012, 11:47 PM
ernestgalvan ernestgalvan is offline
Mein Auto: BMW 740iL 2000 (12/1999)
New Owner: 2000 740iL swapping in MK3
I bought a 2000 (12/99 build) 740iL.
It came with a MK2 nav computer, and I just snagged a MK3 for cheap.
Are there any tips/issues/etc with this swap? Anything to watch out for?
Or is it as simple as "out with the old, in with the new"?
Thanks.
P.S. and yes, I know a MK4 is much more desirable, but the MK3 was only $150.
Hopefully, within a year I can snag a MK4 and a 16x9 display.
Old 12-31-2012, 01:20 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
I believe it's plug n play. Check www.e38.org to be sure..or any of the nav forums (bimmernav.com or the nav forum at bimmerboard.com).
There's probably info on YouTube...basically there's tons of info about that generation nav systems used in BMWs of that time on the Internet.
Q {BMW CCA Member #191509}
(SOLD)
Old 12-31-2012, 02:44 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
As Q stated above, it's basically plug & play.
However, you do need to move the skinny, black antenna cable from the seperate trimble unit (which is now not needed & can be removed once your MKIII is installed) & plug it into the back of your MKIII.
The MKIII (& the MKIV) both have internal trimble units, while the MKII has an external trimble unit.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 01-01-2013, 08:45 AM
ok, Thanks for the information..
But I guess what I was asking was...
"Is there anything that needs to be done to the unit before disconnecting it?"
"Is there anything that needs to be done to the unit after replacement?"
I know some modules are "locked" or "married" to the specific vehicle, thus needing specific sequence of events to prior to removal...
I've read up on the steps needed to physically remove and replace...
but there was SO MUCH info that I was worried I may have missed some vital "point"
Old 01-01-2013, 10:22 AM
Nope.
If your MKII was still working, I'd say to wait until the red LED light on the MKII goes out before unplugging it.
Otherwise, just unplug the old, plug in the new MKIII (with the antenna cable) & you're good to go.
No special coding needed, nothing to "synch up".
It may take a bit for your new MKIII to see the new sattelites in your area unless the MKIII came from very close to where you live.
Old 01-01-2013, 10:53 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
With the MkIII its important to let the red go out before disconnecting it Mks I,II,IV don't need this step. Doesn't the MkIII need a software key as well?
Old 01-01-2013, 01:39 PM
Only if you're trying to update the Nav OS on the MKIII, and only when it's updating to a certain range of OS versions (but I totally forget which versions require a key CD by now).
Old 01-09-2013, 11:22 PM
OK, MKIII arrived, and has been swapped in five days ago.
Seems to be working, BUT map and co-ordinates still show car 2400 miles away
(in original location, Lake Oswego Oregon).
The longest trips have been no more than 50 miles ... probably 200 miles total since MKIII installed...
How long does it take the GPS to aquire its new postiion?
Is there a way of "re-setting" the unit?
Might the unit be defective?
e38, mk3, mkiii, nav, upgrade
HTML code is Off
