Old 12-31-2012, 11:46 AM
SonicBoom SonicBoom is offline
Gearhead
Mein Auto: 2007 X3
Did I find an OEM seat heater replacement for cheap? $100
Yep... me too. My drivers seat heater in in meltdown mode.
After reading the many helpful threads on here (thank you one and all), it seems the replacement parts are ridiculously priced....
But what is this??? Is there someone in Atlanta that can check this out?
http://parts.bmwofsouthatlanta.com/p...117249277.html
Yes, I see it is for a 2010.. but if it plugs right in, perhaps I can place it beneath my existing leather?
Thoughts?
Old 01-01-2013, 06:59 AM
x3brian x3brian is offline
Mein Auto: X3
The biggest challenge will be installation. Its a bit of a PITA to get the seat cover back on but here is a write up:
http://forums.bimmerforums.com/forum...d.php?t=669338
It's for a e46...but should be very similar. I had one saved for the e83 but not quickly finding it.
Old 01-01-2013, 09:01 AM
Gearhead
Mein Auto: 2007 X3
Thanks! Do you know if this heater from Atlanta is a direct plug in
Sent from my XT907 using Bimmer App
Old 01-01-2013, 09:37 AM
Mein Auto: X3
Real oem lists that part for the f25.
http://www.realoem.com/bmw/partxref.do?part=64117249277
I do not see a separate part number for the e83...but I might be missing it. Here is a comfort seat for the 07:
http://www.realoem.com/bmw/showparts...05&hg=52&fg=10
I see the heating element but it lists it with the seat cushion.
I can't see the plug layout to compare.
Old 01-01-2013, 04:20 PM
Gearhead
Mein Auto: 2007 X3
Yeah, I'm trying to find a way to get a new seat heater in there without buying the entire 07 style assembly. The 07 assembly goes for about a hundred bucks.
Old 01-01-2013, 04:21 PM
Gearhead
Mein Auto: 2007 X3
Also, I only need the seat bottom heater. The back heater works fine.
