E60 (2004 - 2010)
Old 12-31-2012, 03:25 PM
RipSnort535i RipSnort535i is offline
Mein Auto: 2008 BMW 535i
Coolant Flush
I'll keep this one simple. How often should I do a coolant flush?
2008 535i Platinum Grey/Grey Dakota/Sport/Premium/Paddles/Bamboo/Nav/PDC
Old 12-31-2012, 10:08 PM
kskane kskane is offline
Mein Auto: 2004 BMW 525i Auto
IMHO anywhere between 35-50K's would not harm your car. Question, I ask is how to do you flush it ? I only drain my E60 M54 525i radiator, as I don't know where the engine coolant drain plug is. So are you referring to flushing or draining? And if draining, how do you drain the engine block. Can that be done by disconnecting the lower radiator hose?
Old 01-01-2013, 04:56 AM
Mac Hadley Mac Hadley is offline
Nac
Mein Auto: 535XI, 328I
I view coolant as more of a time sensitive, rather than mileage sensitive issue. While BMW says it now is a lifetime fill, I change it every 4 years.
Old 01-01-2013, 05:25 AM
todd92 todd92 is offline
Mein Auto: 07 X3, 05 ZHP
5 years
Old 01-01-2013, 05:44 AM
Originally Posted by Mac Hadley View Post
I view coolant as more of a time sensitive, rather than mileage sensitive issue. While BMW says it now is a lifetime fill, I change it every 2 years.
Very helpful. Thanks to all for the replies.
I am approaching 60k and need to look at some preventative maintenance.
Old 01-05-2013, 07:40 AM
Fukukita Fukukita is offline
Mein Auto: Audi A6
Changed mine at 45K miles
Could find the engine block drain plug so only changed the radiator fluid and whatever I could squeeze out of the hoses leading to the pump. Drained close to 7 liters although capacity is ~11 liters.
I will change it again in a few years.
