Old 12-31-2012, 06:38 PM
TedOakley TedOakley is offline
Mein Auto: 328i 2007 BMW
Buttons on steering wheel
I guess something got spilled on the buttons on the steering wheel so when I push one i.e. info for navigation or channel changing sticks in and will not come back to correct position. Does anyone know what I could use to clean this up versus taking it in for the dealer to take the steering wheel,apart?
Old 01-01-2013, 06:44 AM
PaulE90 PaulE90 is offline
BMW ****ie
Mein Auto: E90 320D M-Sport
Silicone spray should do the trick I'd think - at least it won't harm any electrics. Just be careful about spraying it all over your steering wheel!
Old 01-01-2013, 11:27 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Y'know, that's a good question. Are those membrane switches like they oughtta be? Then they'll clean up with warm water.
Guessing what spilled was....organic....
I'll havalook at my Bentley.
Old 01-01-2013, 11:36 AM
Not a whole lot to 'em - this is my model.
Can easily replace if cleaning fails. Looks like the bolt in from the rear.
Old 01-02-2013, 07:48 PM
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Mein Auto: 2008 335Ci
I wouldn't use any chemicals .... no telling how it would react with the plastic.
Warm water with a drop or 2 of dish washing fluid and a soft small paint brush should work. A little water in the wheel won't hurt. I'd tilt the wheel into the most downward position too to keep the water in a non critical section of the wheel.
No matter how fast I go, there's always someone slower in front of me.
You can lead a horse to water, but you can't make him jet ski.
'08 335 E92, M-Sport, 6 sp auto w/paddle shift
JB4 PNP G5 ISO, progressive meth flash, 3" charge pipe w/dual CM5 nozzles, 60% meth injection, Oil Catch Can.
CCA Member 109065
CQ ... CQ...Kilo Charlie 3 Bravo Whiskey Zulu calling CQ
Old 01-02-2013, 08:09 PM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
pull it apart and clean the buttons
If you like customer service. Don't look beyond a BMW.
Old 01-07-2013, 01:42 PM
Leekay07 you said pull it apart and clean buttons. How would I be able to do that as no screws in back a do't think can get access to them.
I tried silicone spray and it didn't work. Then I tried windex and spayed a bit in them and seemed to help as aren't as bad as they were. Guess will just need to do it again. Also discovered the bottom for navigation on middle console is having same problem.
