Old 01-01-2013, 09:16 AM
upandown upandown is offline
Mein Auto: '06 325 - '82 Porsche 911
Quandry at 92k
5 speed 325. It's been a wonderful car...now the 'but.'
Two weeks ago, the car would not start due to a failed valve adjustment motor in the engine.
$2500.
Last week...my daughter wrecked 3rd gear with a bad shift. It grinds and chirps.
Have yet to install a used (87k mi) transmission and clutch.
Estimate is $3100.
Valve cover is fine.
What is down the road for me if I keep this car another three years at 18-thousand miles annually? Any thoughts? Estimated annual repairs?
I hate to lease something like and Acura TSX, but it's cheap, more practical, ....and I do own a 911 to feel the wild side.
Thank-you.
Old 01-01-2013, 10:35 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
$2500.
Estimate is $3100.
What is down the road for me if I keep this car another three years at 18-thousand miles annually? Any thoughts? Estimated annual repairs?.
Naturally, you've seen Bill Arnold BMW in San Rafael. Much preferred over having to deal with local dealer's pricing and SA's.
Alternative: DIY valvetronic motor replacement & transmission R&R. Makes ownership so much more satisfying. Bentley, of course.
Old 01-01-2013, 12:56 PM
floydarogers's Avatar
Pedant and Curmudgeon
Pretty sure you have a 6 speed...
The Valvetronic motor replacement should not have cost $2500.
$3100 for a used transmission and R&R; ok, but probably can be done for less. You might consider going to a normal transmission repair shop that does Getrag trannies; repair is not a hard job (I would not do this for an automatic.) You might consider replacing the clutch plate, disk and throw-out bearing (although they seem to last for 150K+ if not thrashed).
I would keep it - the car is worth $10K-15K if the work is done, and should really have anything else go wrong.
www.bimrs.org, www.bimmershops.com for non-dealer repairs.
Old 01-06-2013, 09:33 PM
Update
Yes...a 6 speed. '5' was a typo. The car is gone. It appears to have found a good new home. And yes, I did speak with Bill Arnold. He seems to be a great guy, but quoted 61-hundred dollars for a new trans and clutch. Add the need for a new battery, brakes, a tune-up, tires in 10k miles, and whatever else, and I purchased a Volkswagen CC. It's not quite a bimmer...but not a bad drive at all for daily commuting. Kinda like it, actually.
See y'all in three years or so, when the daughter graduates college, I retire, and buy that last car.
Thanks for the advice.
Old 01-06-2013, 09:46 PM
tturedraider's Avatar
Freedom isn't free!!
.....I retire, and buy that last car.
I hope that means you're gonna be 90 y.o. when you retire and you're not planning to have your last car for 20 or 30 years.
www.bmwcca.org
Old 01-07-2013, 03:28 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Now, I didn't do this, but a friend commented that when the last one graduates college, it's time to buy your first motorcycle.
