Old 01-01-2013, 06:34 PM
speedninja speedninja is offline
Big Body Speed
Mein Auto: 01 525i, 09 328x coupe
Exclamation Tire Size
Can i put or should i say will 245/40/18 work on my 328 xi coupe all the way around.
Old 01-01-2013, 07:37 PM
floydarogers's Avatar
Pedant and Curmudgeon
The correct size is 225/40R18. 245 will be a bit tall, although it will fit in the wheel well.
Old 01-01-2013, 07:44 PM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
Isn't 245 tread width?
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 01-01-2013, 08:55 PM
Yes, but 40% of 245 is taller than 40% of 225, so the tire will be too tall. By 16 mm or about 3/4 inch.
Old 01-01-2013, 09:16 PM
Big Body Speed
but will it fit with out any rubbing im doing 245 to protect my rims from the curb rash...from the this winter
Old 01-01-2013, 09:36 PM
vstM3's Avatar
vstM3 vstM3 is offline
Mein Auto: F80 M3
I got 225/40/18 all around for winter, that's what bmw recommended. Hope this helps
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is
Other: 2014 Mini Cooper
Old 01-01-2013, 09:41 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
I believe the staggered setup for our cars uses 255/35/18 on the rear so to floydarogers point you probably don't want 40 aspect ratio. As for rubbing I ran 235/45/17 up front and it was very tight, but didn't rub. I am guessing 245 would rub on front. There is plenty of room in the rear. Of course my experience is with the rear wheel drive version - not sure how much different the AWD is.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 01-01-2013, 11:27 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Our autocross setup on the 335is Coupe is a square setup with 255/35-18 all around, but these are on Apex ARC-8 18x8.5 ET32 wheels, which are similar to the stock rear wheels on our car.
I first tested fitment by just swapping the staggered stock wheels and tires from front to back and vice-versa, putting the stock 225/35-18s in the front. I took the car down to a local school parking lot on the weekend and ran it hard to check for any rubbing or bumping but it was fine.
No reason why this wouldn't fit on your car, unless the xi has less clearance.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 01-02-2013, 08:52 AM
3ismagic#'s Avatar
3ismagic# 3ismagic# is offline
HerrDoktorProfessor
Mein Auto: '11 335d
I did 225-40-18 all around on the stock staggered wheels. You want narrower tires in the snow not wider
Entertaining America Since 1975
European Delivery July 26th 2011
ED Video:
ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294
335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns
BMWCCA #448878
Old 01-02-2013, 09:11 AM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
I am running 235/45-17. Tire Rack advised that 245/45-17 would rub. Hope that this helps.
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
