Hi. I need help with my bimmer its 97 z3 1.9L with 200,000 miles. Idles good but it seemes its slow on take off and bogs down when driving cold or hot. I had p0340 code and it went off after I replaced the CSP sensor. Also replaced the fuel filter. Oil/filte. Spark plugs. Put cleaner in the tank. No vacumm leaks. No obd codes. New cat converter. And new battrey. All that didn't help. The car starts right up idles good but when I accelarate its easy to notice the car is slow. I drove 70mph so it goes if u give it a time but again still slow. What else could it be? Any thing common with these cars/engines? I have actrun obd scanner reads live data anything I should look for? The car was setting for 2 months and had to put new battrey would it cuz the car to go in limo mode? Does this sound like limp mode? If so how to rest it? I dissconnacted the battrey for like 1 hour and didn't help. Thanks for all the advices
It's not a "beemer", it's a bimmer (hence the name "Bimmerfest").
Model-specific questions are best asked in the forum for that model. In your case it would be the E36/7 Z3 forum.
- Tom ------- Mine: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12Hers: 2011 335is Coupe (E92) | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11 BMWCCA #444696 - Click to join and a chance to win a 1-Day M School at the BMW Performance Center!
Oh really man I never would of guessed. Wow you are so F@@#ing smart. You're answer really fixed the problem. It will be great if ppl have no answer stop writting sh@%&
Tim |
Thank you very much Tim330i. I posted questions on yahoo answers and it seems lots of ppl just joking around about high miles and telling me this is the end of the engine life and I know its not true. And asking me to replace parts I already did!! And said I replaced in my question. Like fule filter. I thought I might have a better shot in BIMMER forum and there was the first guy teaching me about how to spell Bimmer instead of just keep to himself if he had nothing good to say. Anyways thanks again Tim330i.
The members here are into the BMW brand, I don't think it was meant to be an insult.
Tim |
Might be time for a new fuel pump.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors |
I'm assuming you have a 1.9L.
When my car was bogging down a bit, I had a rip/hole on the air tube. See pic #3. Take a look at yours.
1996 Z3 (M44) |
1.9L. The car does not have that tube at all!! Number 3 is missing!! All other parts are there, all the plastic covers/guids are there. Well I hope that's the case. I'm checking the part stors if not I might get lucky on ebay or pick n pull. I was planing on taking the MAF a parts and clean all of it inside out. But I'm gonna try with the hose/tube first. Man I hope its the problem cuz its easy fix I really don't wanna deal with big issues cuz I'm moving out in 3 days and baby girl on the way in March so I love my car but don't have much time nor money to guess on expanssive parts. IgotBMW thank you very much for the help
The fuel pump would be the last opition cuz of the price and it's location, it might be weak but I think it's not fuel pump at least I hope it's not. Air flow seems more like it and when I first took it on test drive after the work I thought for sure sounds like vacumm leak but checked carefully for that and all hoses look good no vacumm leak. Now after IgotBMW menitioned hose/tube #3 I think he just helped me find the problem. I'll sure report sometime tomorrow with the good news hopfully. Thank you tho
So do you have an aftermarket intake or just the stock airbox? If it's the latter, you may not be getting enough air into the manifold.
1996 Z3 (M44) |
I have the stock airbox, verything stock on the car. Like the pics shows here.
Can you take a pick of yours. So you must be missing the black piece on top of the radiator that's how you know the #3 isn't there. Because #3 is underneath that.
That allow air to travel from the right side opening (next to passenger headlights) to your air box. So your airbox isn't getting proper amount of air then.
1996 Z3 (M44) |
I took all the plastics in the front of the radiator there are 2 pieces mounted to gather nothing in between!! I can see where the tube should of been. I don't remember seen the tube when we got the car cuz some parts were in the trunk!! The tube is missing for sure, I see it should go from the Airbox to the hook up next to the passenger headlight. I'm trying to figuer out something for it I'll report back when I get tge tube and install
The tube is a snorkel that protects against water entry, but it restricts air flow compared to no tube, and pre-heats the air with heat from the radiator. "Fogging" the air box -- removing the tube and making another direct opening -- is a popular mod: http://www.bimmerfest.com/forums/sho...hlight=fogging http://mz3.net/1-9-fogged-airbox-modification.html http://ackthud.com/shawnfogg/1_9airbox.htm Last edited by vintage42; 01-30-2013 at 09:41 AM. |
I went to the yared and bought good tube no rips or holes and installes it. It did not change how the car drives at all. I still think it has to do with the air system!!
Ok so now it's confirmed the issue is not the tube because the car is idling and driving the same but I'm sure the car needed it for other reasons!! A guy looked at it today and said it will be timing chain off or the car in limp mode. anybody knows of ways to get it out of the limp mode? Or how to confirm the car in fact is in limp mode other then lack of power? What happens is the car always start up from the first cilck and idles good. Also it drives good when you're driving like 70 year old man but if u try to go fast and eccelrate all the way the car won't go as fast as it should. When I'm on the road going about 50mph and push the gas padle all the way in the car still down shift but it will not go as fast as it should. Again the car is fine if yiy drive slow and pick the speed one by one, I went to change the trans oil and the my friend/mechanic says can't it's life time trans oil. can't service it!! Lol really BMW? Nothing is life time it's freaking oil and has to be changed sometime. When I first got the car I was very happy but know I think I should of bought Grand prix GTP they are good cars and easier to work on
This 70 year old man has the same car you do except with a Supersprint axle-back, and he accelerates to redline and it goes plenty fast.
I was thinking about the spark plugs I put on the car, they were utolite Platinum/Spark Plug as showing in the pic, I wanted to get the best for the car and the girl at Autozone told me those are the OME ones that BMW recomended for my Z3, well the ones I took off from the car looked diff at the end of the plugs. The old ones have 2 ending unlike those one I got now
I'd like to see 70 year old man get it in redline, he'll get the most hits on youtube
What did you expect? Last edited by dougmcintyre; 01-31-2013 at 07:56 AM. |
Here is what NGK said about using another plug that was wrong: Quote:
Great info Vintage42. The idea when I took the spark plugs out is to see how bad they might be and get the exact ones new. When I went to autozone and the lady should me what they got on the computer I said mine dosn't look like that. It has to ends not 1. And I bought what she told me that was OME and thar is what I should use. Also I looked on thier website for 97 z3 spark plugs and shows nothing with 2 ends. Well today I cleaned the old ones and put them back the car drives much better. I'll put new soon!!. Although the car still have a little lack of power when accelerating. Not to much tho just a little. Heres what I found out today. The car has switch A and M auto and manual. So when I switch to M and drive manual from 1-2-3-D the car seemsto have way more power!!! Strange. Is it set up this way auto D a little slower then M? I'm talking full power when using M and do 1-2-3-D. Any idea? Thank you all for the great usefull info
Ok,
I don't know anything about the 1.9's auto transmission. But I'm not afraid to use the search: Quote:
