E34 (1989 - 1995)
Old 01-01-2013, 09:06 PM
Bjm535i Bjm535i is offline
Mein Auto: 89 535i
Drivers door won't lock
My drivers side door won't lock with the key. Also couldn't manually lock it either. Pulled the door panel, checked the actuator, it's fine. Pulled the door lock it's fine also. I can manually lock the door with the actuator disconnected and the rod to the key lock, so it seems to be the key lock. Does this sound right, so does it sound like I need to replace the handle - key assembly. If I do ,is there a way to use my existing key.
Old 01-01-2013, 09:20 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
I replaced the lock cylinder in a 93 e36 and it wasn't that bad. Probably similar or the same lock. Anyway you just take the tumblers out of your lock (keeping them in order) and put them into the new cylinder. Then your key will fit.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 01-03-2013, 01:19 AM
Mein Auto: 1989 525i M20B25
Does the actuator arm move in and out?
Old 01-03-2013, 07:57 AM
Mein Auto: 89 535i
It does. It seems that the problem is in the lock assembly. The rods going to the actuator and to the door latch from the assembly wont move when the key is turned either direction. Can unlock and lock passenger door with key from this door. You can see the actuator trying to move ,but it can't. Disconnected the rod and it moves freely.
Old 01-03-2013, 08:51 PM
BMWFatherFigure's Avatar
Old School
Sounds like a mechanical problem in the lock. Take it out, clean lubricate and check. Could some @#$%^* have had a go at stealing the car and dameged the lock parts?
Current:
E38 Parts Car
Previous:
Old 01-04-2013, 02:16 PM
possible....
could be something metal dropped in between moving parts.
Old 01-06-2013, 02:12 PM
Mein Auto: 89 535i
Thanks for the help. I totally disassembled the lock. Think it was put together wrong. Got it working.
Old 01-06-2013, 03:06 PM
Nice!
Old 01-06-2013, 10:00 PM
Old School
Gotta love a thread with a happy ending....
Current:
E38 Parts Car
Previous:
