F10 ER_KEYOUT_AUTOVR Not Working - Bimmerfest - BMW Forums
Old 01-01-2013, 10:41 PM
weissja weissja is offline
Kaos
Mein Auto: 2014 550i M Sport
For some reason, ER_KEYOUT_AUTOVR is not working on a 2013 F10 550 (October build). From the threads, it seems like it is working for some, but not all. If you are having this issue, so the experts here can figure this one out, please post what year, model and ISTA/P version you have.
Old 01-02-2013, 04:44 AM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
You have to set the car to automatically close the door after you drive off for the doors to automatically open after shut off...If the doors dont lock themselves it will not unlock after shutoff
Old 01-02-2013, 12:06 PM
Kaos
cn555ic,
You're correct. Finally worked once the car locked automatically. When I hit the start/stop button once, all doors unlocked. Thanks for your help.
Old 01-02-2013, 06:33 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Are you saying that if you don't have auto lock on, that after you drive off and manually lock the doors, ER_KEYOUT_AUTOVR won't work either? It only works with auto lock on?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 01-02-2013, 06:37 PM
Mein Auto: bmw
yes...The car has to be set to autolock on its on when you drive off, then and only then will the doors automatically open up after the engine button is turned off..It you press it to lock itself physically, then it will not work later to auto unlock
Old 01-02-2013, 06:40 PM
Ok. Good to know. Mine is set that way, but I always assumed so long as the doors were locked, it would work. Kind of makes sens though that it needs to be in auto lock to work.
Old 09-28-2015, 11:00 PM
spadae2 spadae2 is offline
Mein Auto: 2015 750ix
F025 15-03-503. Has this been replaced? TX,
ER
__
2015 750i X-DRIVE, M-Sport, (born 3/6/2015), Moonstone Metallic, Ivory White/Black w/Honey Walnut, ARS, B&O Sound, Escort 9500ci. VO and FDL Coded. BMS Stage 1.
