E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
INPA or Bavarian Technic
Happy New Year! I am in the market for a code reader to reset an airbag light. I have a 2006 3.0si Z4. I have two in mind and would like your input as to which would be the better option. I know the BT is around $300 and good for 3 VIN's and fairly user friendly. The INPA is much cheaper $20-$50 but less user friendly. However, I am fairly computer literate and comfortable around the technical side of things.
If I just want to get the airbag light and reset the code, is the INPA the better option? Thanks in advance, Jerry |
I use INPA. Once you get it installed properly and use it, you start to figure out what it is trying to do and it get rather easy.
I also have the AutoEnginutiy with BMW extras. INPA beats is hands down for what you can monitor/control and reset on the car.
. How does something immoral, when done privately, become moral when it is done collectively? Furthermore, does legality establish morality? Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of more people. Walter E. Williams Drives a 2008 Z4M Coupe' (His) & 2003 Z4 Roadster (Her's) |
Thanks Shipkiller. I really appreciate all of the advice you give on the forums. I have learned a ton just reading through the multiple posts. After a little additional research, I found that the software only works on computers with a 32 bit operating system. Unfortunately, both of ours are 64 bit. I will either have to find a loner 32 bit laptop or go with the BT. Thanks again for your post.
Jerry |
INPA.... WILL work on Win7 64. My primary diagnostic laptop is running Win7 64 and it works great. The only piece of software (I know of) that does not run on a 64bit system is NCS Expert, which is the software you use for coding/recoding which you will not use very often....
I do have a VM that run 32bit XP on it so I can do coding... I have a full INPA install on the Win7 side, I just don't use NCS Expert, and a full install on the VM. I can switch to and from at will. DO NOT use WinXP mode VM from Microsoft. While it works, it runs VERY slowly.. VMWare runs rings around XP mode...
I found a good deal on a BT on Craigslist. I was amazed at how easy and user-friendly the BT was. My airbag light was diagnosed and erased within a couple of minutes. The code it threw was ZKO. I did a lot of Googling, but didn't come up with much information other than it might be a loose wire/connection in the steering wheel. After 4 days, the light hasn't come back on so I am hoping it stays that way! Just glad to have that stupid yellow light off for the time being. Once I have some more time, I plan to explore the software a bit further. If the light doesn't come back on, I might sell the BT and come out close to even. Better than paying $120 to have the dealership for a 2 minute job.
Jerry |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
