Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 01-02-2013, 09:27 AM
MPA2011750LIX MPA2011750LIX is offline
Mein Auto: 2011 750lix
2011 750lix rear tire wear
I was told by the dealer that I need to replace the right rear runflat due to tread wear as,
it wears uneven compared to the other tires. Is this accurate?
I purchased the car in 9/2012 with 29,000 miles from a Mercedes dealer. It now has 36,000miles. The right rear tire definately has much more wear than the other 3 which have fairly even tread wear.
Also, can and should I be rotating the rear tires (275)? Thank you.
