E34 (1989 - 1995)
Old 01-02-2013, 05:26 PM
hdbtony hdbtony is offline
Mein Auto: 1989 535i
help need. strust size 1989 535i
Want to buy coils but need strut size ?!?!?
Old 01-02-2013, 06:12 PM
Banned
Mein Auto: car
Less akin to " wanna buy bra but need cup size" and more like " Wanna buy shoes but need bra size ! " LOLOLOL
For heaven's sake, please write normally, please tell the whole story, if not nobody will bother replying to you anywhere.
Old 01-02-2013, 06:27 PM
That was funny okay your right
I need to find what my strut size for my suspension
For my 1989 535i I looked around google and said it should be the same as an e30 which is 51mm
But I'm not sure ?
Old 01-02-2013, 07:09 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Why not order springs by vehicle application? There are tons of choices... H&R, Eibach, Bav Auto, Vogtland, Lowtech, and probably a couple of others. You can rest assured, they wont ask you for your strut size
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 01-02-2013, 07:41 PM
I thought about it but I'm kinda of a crazy driver so I wany my handling to improve by a lot and it would get rid of most of my body roll in turns
Old 01-02-2013, 07:48 PM
Banned
Mein Auto: car
You could use a front strut bar, that will get rid of a tremendous amount of body roll quickly, but be forwarned, the car will be less exciting once it is installed, and in terms of vehicular stability geometry-wise I don't think it makes much any difference....
Old 01-02-2013, 07:52 PM
Yeah idk about that then
But I still havny found the strut size -.-
Called bmw earlier today and they didnt know just the weight ect .
Some one said it was like an e30 51mm but idk -.-
Old 01-02-2013, 10:56 PM
BMWFatherFigure's Avatar
Old School
E30 use different strut inserts depending on engine size. Here is a radical suggestion - take your strut insert out and measure it. While it is out go to the local suspension shop and buy the replacement of your choice - performance or standard. This has worked for me in the past.....
Current:
E38 Parts Car
Previous:
Old 01-03-2013, 04:43 AM
The Ornery Old Man
Mein Auto: GTI
Or if you are truely serious about being a road racer, buy a set of coil overs and set it up as you wish. Again, you will not really need the measurement you are looking for.
Do you plan on using this as a track car? If not, just about any of the sets listed with lower the car, reduce body roll and improve you handling. Going any further is a waste of time because if you go much stiffer the car will be miserable on the road.
Old 01-03-2013, 06:58 AM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
Nope.
First off, improving the sway bar bushings is really what's important. Replacing the stock ones with Energy Suspension's better design will make a dramatic change. Switching out to an M5 bar from a salvage yard would be an excellent score. Getting real spendy with a Racing Dynamics sway bar kit would have the car handling like it's absolutely on rails, even with the stock 15's.
If that doesn't put a smile on your face, then the next stop would be a set of Koni or Bilstein dampers.
Any positive change in the sway bar performance will add to the spring rate during during cornering...with only a comparatively minor reduction in asymmetrical bump response. That's what you're really looking for.
I highly recommend leaving the springs alone unless they're completely unserviceable or you're trying to drop the trim height (which also won't reduce roll as much as messing with sway bar).
Good food, good people, good times.
