Hood Emblem - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 08-23-2013, 05:04 PM
3RZ 3RZ is offline
Mein Auto: E34 530i
Hood Emblem
So I decided to replace my hood emblem. Naturally, since I am always destined to screw up something when working on a car myself, the pins on the old badge cracked off the badge and are now stuck in the grommets in the hood. Fantastic.
Before I bust out the dremel and "machine" the old plastic out, does anyone know if I can push out those rubber grommets from behind the hood? I have the wider kidney grill since mine is a V8, I'm not sure if there is a difference though.
Thanks.
Old 08-23-2013, 06:19 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Hahahahaha... O man.. No dremel please.. There should be away to pull the grommet out with pin in it via needle nose pliers or a small pick of some sort..
Id avoid a dremel, will ruin a grommet at least if not widen the hole odly..
Old 08-23-2013, 08:53 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Re: Hood Emblem
Thanks.
This is the first thing I do when we purchase a vehicle from the auction is replace the emblems , so I have a few that I have replaced . I'm surprised that the new emblems you purchased didn't come with new rubber grommets . You can buy them separately from your local BMW dealer they are about a dollar fifty each ( our cost anyways ) the old emblem pins and grommet I just push into the hood , don't worry it won't rattle ...
Sent from my Desire HD using BimmerApp mobile app
Old 08-24-2013, 06:32 AM
3RZ 3RZ is offline
Mein Auto: E34 530i
Thanks for the advice. And yeah, a dremel is a stretch for me too. The car's paint is very messed up already though.
Old 08-24-2013, 04:48 PM
3RZ 3RZ is offline
Mein Auto: E34 530i
Alright. Grommets came out with needle nose pliers. They pretty much crumbled apart actually. I found new ones in the ash tray. I guess I got lucky.
