Old 01-03-2013, 06:52 AM
stussy stussy is offline
Mein Auto: z3
Smile Hi, Sure its been asked before :)
Hi
Im sure this ones been asked before, but....
I have a 1.9 early Z3 cab, and its getting through rear tyres especially on one side at an alarming rate (i dont drive like a girl racer... much) its also developed a bit of a humming when driving, one of the rear wheels (on the opposite side to the badley worn tyre) feels a bit like a bearing may be a bit worn?
Im guessing the tyre wear is something to do with the camber/toe in, but not having had this type of car before im not sure where to start looking, im quite used to working on my own motors, but was just after a few pointers of what to check out first.
Claire
Old 01-03-2013, 06:55 AM
Mein Auto: z3
Just to follow up, reading through other posts, sounds like there is no adjustment in the back, so i guess that leads me to thing something is bent/broken to push it so far out?
Old 01-03-2013, 07:57 AM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
There is no adjustment that comes stock from the factory. There are after market toe and camber kits available. Any car that has been lowered with shorter springs or coil overs will have an increase in negative camber. The only way to fix it is to add the aftermarket toe kit. Most leave it be as the increase in tire wear is usually not to bad. A car with a bent rear suspension will have the toe out of spec. Either replace the rear suspension or if it is not bad, the toe kit might get you back within spec. Either way, the first thing to do is pay $80 and get a 4 wheel alignment so you know what direction to go and what to look for unless you can see bent parts.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
Old 01-03-2013, 08:10 AM
Kornknarr Kornknarr is offline
Mein Auto: -98 Mroadster S50 Estoril
Only on one side? Check springs. Humming could be a bearing - yes. If a spring is not broken I would take it to someone to look on the rear suspension as a whole as Wertles above recommends.
Old 01-03-2013, 12:01 PM
GA Z4 GA Z4 is offline
Mein Auto: 2004 Z4
How are the tires looking, I had a simaler thing and the tire was actually cupped a bit, you couldnt see it without a pretty careful look, if one is wearing the other may have some issues as well.
Old 01-03-2013, 06:45 PM
yellowjack yellowjack is offline
Mein Auto: Z3, 2.3 2000, Passat 1.8
I have the same issue right before i put the car in storage this winter. I talked with my mechanic and thniks the springs are borken, some I have to take care of before I put a new set tires on.
