Old 01-03-2013, 08:03 AM
__co__ __co__ is offline
Mein Auto: '04 645CI
Replace iPod interface with original CD-changer
Hi,
2 years ago, I had an OEM iPod interface fitted which replaced the CD-changer in my '04 645CI. Since I'm selling the car, I want to put the CD-changer back in the car so that I can use it in another car (or sell it separately since they are worth a few ).
My question is, can I just replace the iPod interface with the original CD-changer or does the car require recoding after this change?
Old 01-03-2013, 08:26 AM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
Originally Posted by __co__ View Post
Hi,
2 years ago, I had an OEM iPod interface fitted which replaced the CD-changer in my '04 645CI. Since I'm selling the car, I want to put the CD-changer back in the car so that I can use it in another car (or sell it separately since they are worth a few ***8364.
Since most of the iPod interfaces emulate the CD changer so it my be just a plug and play. I would just try it, I don't think you could break anything.
Are you selling the interface? I may be interested if you are.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 01-03-2013, 02:17 PM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
When I sold mine I just took out the ipod interface and put the CD change back in, I did not test it as I sold it to a dealer, a private person would have been a different matter!!!!
Always said I would go back to a 6 series
Old 01-03-2013, 02:36 PM
My thoughts are the same Rosang, I think I'll just give it a try this weekend. See what happens
I might sell it, but since I'm living in the Netherlands shipping costs are likely quite high. I'm looking for another car and decision of selling it depends on the installed options on the new vehicle.
I'd rather like the CD changer to work when I deliver the car since I said to the buyer that the car is 100% ok. So I will definitely test the unit.
Old 01-03-2013, 03:33 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
Technically you would need to code the car to change the VO of the car. The CD changer is listed in the VO as option $672, the iPod interface kit is listed as +IPOD.
Just as a point to note the Dension iPod interface unit works with either $672 or +IPOD so the CD changer may also work with both. Don't forget that there are both electrical & optical connections to the CD changer.
If you forget to connect up the optical connector you may disrupt the MOST optical fibre ring & cause the Bluetooth, CD changer, Nav or Radio/CD/DVD to stop working. It's because it relies on it being a ring of connection.
Old 01-03-2013, 03:49 PM
Ok, thanks!
Looking at the CD changer unit, there is only one plug (X18180) which holds 2 optic fibres and 4 electrical pins. I guess i cannot go wrong there.
Old 01-03-2013, 03:50 PM
roseng's Avatar
I'll be in Amsterdam at the end of the month, so shipping should not be an issue. As they say in New York, "Make me an offer I can't refuse"
Old 01-04-2013, 03:56 AM
Hehe, ok. If I'm selling the unit, I will let you know.
Old 01-04-2013, 08:43 AM
roseng's Avatar
Thanks.
Old 01-23-2013, 08:52 AM
Just an update: I removed the iPod interface and refitted the CD-changer. Worked like a charm without recode.
Roseng, I bought another vehicle which also needs the iPod retrofit, so I will most likely use it in that car. So at this moment, I'm not selling it (sorry )
Old 01-23-2013, 02:47 PM
roseng's Avatar
Too bad. I'm heading to Amsterdam on Sat. and I was going to check in with you. What did you replace it with?
Old 01-24-2013, 01:56 AM
Another '04 645, but an E64 with low mileage and many options. I had a Z4 before and I missed the convertible top
I looked for a younger car but in the Netherlands they are just too expensive, unless you look at the vehicles with +100K miles on it. With the N62 coolant leakage issues in mind, that wasn't an option for me.
Old 01-24-2013, 09:43 AM
roseng's Avatar
I am aware of car prices there and I understand. Hopefully you are not in Amsterdam as I am also aware of the parking prices there too.
Good luck with the new ride.
