Old 01-03-2013, 10:21 AM
Coochie_Bandit's Avatar
Coochie_Bandit Coochie_Bandit is offline
Mein Auto: 540
Oil filter housing seal?
Before I order A new seal I would like to verify and make sure. I Pulled into a parking lot and not 10 went minutes went by before I noticed the little puddle of oil in front of my front left tire. Open the hood and found another little puddle under the OFH.
Took these pictures below with my phone.
ID:	355768   Click image for larger version
ID:	355769   Click image for larger version
ID:	355770   Click image for larger version
ID:	355771   Click image for larger version
Old 01-03-2013, 10:44 AM
Fryed Fryed is offline
Mein Auto: 2001 M5
What brand are the filters you're buying? I made the mistake of doing a quickie oil change once, picking up an "OEM" filter at AutoZone or some such place, and having a similar problem. In my case, the rubber gasket around the top of the cap was too small, and the oil pressure was forcing small amounts of oil out between the plastic cap and oil filter housing.
Now, I always buy Mann filters off Amazon.
I happen to have $80 laying around and I'm wondering what can I buy to make the 540 perform better or look better with only $80.
full tank of 94 octane
Old 01-03-2013, 11:18 AM
Mein Auto: 540
Now that you mention it I had bought an oil filter, STP, it was from autozone.. But used the same o-ring it previously had. This was back in july. I've has no previously leaks from this area before.
It might be worthy noting that I havnt started the car up in 2 days. And maybe the low temps in the northeast have taken its toll on this seal.
Old 01-03-2013, 11:29 AM
Mein Auto: 2001 M5
Get a Mann filter, they're dirt cheap (Like, under $10 on Amazon). If you have prime, free shipping!
Replace EVERYTHING when you do an oil change - filter, gasket, and that little metal washer. I've even gone so far as to replace all the filter housing mounts (they're rubber, about 1/2" thick, and turn to solid chunks of brittle garbage after a few years).
That should solve your problem!
Old 01-04-2013, 12:17 AM
Mein Auto: 540
Are the connections at the bottom of the housing unit prone to leakage?
Old 01-04-2013, 09:13 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Now that you mention it I had bought an oil filter, STP.
I have a bunch of pictures of why to NEVER use an STP oil filter on the bimmer!
It's probably in one of these two threads:
- How not to do an E39 gravity feed oil change (1)
- How not to do an E39 vacuum extraction oil change (1)
Old 01-04-2013, 07:14 PM
Mein Auto: 2001 M5
It's the rubber housing mounts that I'm talking about. They're the items pictured in this post. Littler buggers wear out and the whole housing comes loose. It's a very cheap and simple maintenance item.
