E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135. |
Bmw 1 series - traction control light / judders
hiya all and happy new year..
Please can anyone help, the traction control light is flashing when driving (orange triangle with a clockwise circle arrow) then the car starts to judder/losing power, when the dtc button is pressed on the car still flashes but doesn't judder/lose power under 40mph....... If anyone could help it would be great, I have had it into BMW who say they dont know what the problem is to cause this problem. If any further info required please ask. Thanks Baggio |
Are you driving in near-freezing temperatures with summer tires, or tires that are bald? If your tires are not bald and seasonally appropriate, maybe it's a clutch issue? |
I have this a little bit in Denver. The ice will cause it to happen. I actually turn off the dcs to keep from having the car lunge and hesitate when trying to accelerate. I would rather have it spin a little than cut out and apply brakes, etc.
JZW |
That sounds like a wheel sensor or something that aids the stability control system. Its tuff when you have an intermittent issue like that. You will need to take it back to the shop and if they can get the problem to occur, then they should be able to fix it for you.
Its tuff when there is no cel and the problem does not occur while the shop has the car. If its happening often enough for them to duplicate it, then they should be able to repair it. Does it happen if you turn DTC completely off ? JZW |
I have had this exact problem and it is a wheel speed sensor. With mine it was a bit worse as it turned out the drive shaft had gone and had moved the tiniest amount and the tolerance on the sensor is minute. This resulted in the sensor rubbing against the drive shaft and then subsequently tricking the car in to thinking one wheel was turning faster than the other making the traction control kick in.
Hopefully yours is nothing more than a dodgy sensor...... |
I have a similar problem... unfortunately I think in my case it's my right leg that's the issue
2001 E46 BMW 330i Sport Package 6MT *SOLD* 2004 BMW R1150GS - *SOLD* 2004 E60 BMW 545i Sport 6MT - *SOLD* 2012 BMW 135i - Deep Sea Blue / Terracotta / DCT 2012 BMW K1600GT - Vermillion Red Metallic http://www.driveblog.net |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
