Old 01-03-2013, 05:49 PM
Studawg's Avatar
Studawg Studawg is offline
Mein Auto: 2003 540iT M Sport
P2187 and P2189 codes ?
System too lean at idle Bank 1
and
Anybody got any input on these?
Old 01-03-2013, 07:51 PM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
Lean codes usually indicate a vacuum leak. The best way to find such a leak is to get the car smoke tested.
You can also visually inspect intake boots and vacuum hoses for leaks.
A failed MAF can also cause such codes but I would check for vacuum leaks first.
VF Supercharger Kit much modified & tuned by FS Tuning Tech,M5 Front Sports Seats,CVV to Catch Can Conversion,Boost Gauge, Schmiedmann S.S. Header to Rear Muffler High Flow Exhaust,Header Ceramic Coated Inside & Out,Heat Wrapped from Header Flanges to & Including CATs,Kicker Sub w/200 Watt Amp,CCFL Angel Eyes,Blackout Facelift Kidney Grills, Quaife LS Diff, Zionsville Super Duty Cooling Kit, EMP Stewart WP, Derale Electric Cooling Fan Ajustable Controller w/2 Speed Circuit (JimLev Design).
Old 01-04-2013, 10:54 AM
Studawg's Avatar
Thats what I thought. I did clean the MAF, and it seemed to run a little better after that. I will start by checking the vacuum lines. CCV maybe?
Old 01-04-2013, 10:59 AM
Fudman's Avatar
Fudman Fudman is offline
Check the corrugated rubber intake boot (between the airfilter box and the intake manifold). These rubber boots tend to crack with age. Especially if it was handled recently when cleaning the MAF.
