Old 01-03-2013, 06:12 PM
JackDuggan JackDuggan is offline
Mein Auto: 2001 Z3 3.0 Roadster
S204A option code "shorter final drive ratio"
I did a VIN decode on my 2001 3.0, w/5sp manual and found an optional axle code of S204A. Does anyone know what that ratio is? I've looked around on the web and can't find a definite answer. I think it might be a 3.15, with stock being 3.07. Anyone know for sure?
Old 11-04-2014, 09:41 AM
big_cg big_cg is offline
Mein Auto: 335i
Anyone find an answer to this? What rpm on the highway will this ratio hold?
Old 11-04-2014, 11:00 AM
I never found out.
Old 02-01-2015, 02:53 PM
cpallenjr cpallenjr is offline
Mein Auto: 2002 Z3 2.5
Z3 Final Drive Ratios
I know that this is kind of old post, but I was wondering the same thing and finally found the answer! Sharing here for good karma.
This example is for a 2001 Z3 3.0i with M54 engine.
BMW Archive - VIN Lookup: Go here to get the details on you car's factory build
http://www.bmwarchive.org/vin/bmw-vin-decoder.html
BMW Parts Site
http://www.bmw.com/com/en/owners/acc...catalogue.html
Log in info can be found elsewhere on this site, or ask you dealer.
Drill down in parts to Rear Axle/Rear Axle Drive:
http://www.etk*****bmw/EN/search/sel...CE/33/33_0385/
Old 02-01-2015, 03:17 PM
Z3 Final Drive Ratios (continued)
The LSD option is shown as a separate bolt on unit that presumably then doesn't affect the final drive ratio, although there are different numbers for each combination:
http://www.etk*****bmw/EN/search/sel...CE/33/33_1075/
The information you have been waiting for:
***8470; Description
1 Exchange final drive with differential I=3,07 33 10 7 508 264
For vehicles with
Automatic transmission(S205AYes)
1 Exchange final drive with differential I=3,15 33 10 7 508 266
For vehicles with
Shorter final drive ratio(S204AYes)
and
1 Exchange final drive with differential I=3,46 33 10 7 508 262
Old 02-01-2015, 03:21 PM
Z3-3.0L Final Drive Ratio Summary
So to summarize:
Standard Transmission: 3.07:1
Automatic Transmission: 3.15:1
Automatic Trans w/ Shorter Drive Ratio: 3.46:1
Old 05-24-2016, 05:59 PM
danomite danomite is offline
Danomite
Mein Auto: SC'd Z3 3.0 Coupe
Sorry to revive an old thread, but in case anyone is looking for the answer in the future, if your VIN lookup includes [Shorter Final Drive Ratio (S204A)], then you have a 3.46 diff....not the standard: 3.07 on manuals and 3.15 on automatics.
Just an update.
You don't win silver...you lose gold.
Old 05-24-2016, 06:26 PM
Thanks, that explains some things. I actually wish I had the 3.07. I don't drive it hard, and I wish it didn't wind up so fast in first gear. But it's something to advertise if I sell it.
Old 05-24-2016, 07:32 PM
KBH22102 KBH22102 is offline
Mein Auto: 1997 Z3 2.8, 2002 M Coupe
Interesting, so which is default/standard on the Automatic? I was always under the impression that 3.46 was standard as I have bought two diffs with that ratio and a 3.0 auto was the source for both.
Old 05-25-2016, 04:21 AM
Mine is a stick, so the 3.46 must have come with both auto and standard.
Old 05-27-2016, 01:05 PM
Danomite
Just an update.
Guys, it's right there in the message!
If you got two 3.46's from cars (regardless of whether they were manuals or autos), then they both had the shorter final drive ratio option.
