Old 01-03-2013, 07:08 PM
BlackMax540 BlackMax540 is offline
I am a rookie again
Send a message via AIM to BlackMax540
Mein Auto: 1999 BMW 540i
I Purchased a New(Used) M62TU from a 2002 540i
I just purchased a Used M62TU today that came out of a 2002 540iA that was hit from the side to put into my 1999 540iA.. The engine has 87k on it and the 5hp24 transmission. Since i have the engine and transmission out of the car I plan on replacing the Timing Chain Guides and Tensioners, rebuild VANOS, and Cooling System Overhaul. What else should i do since it is out of the car?
ID:	355841   Click image for larger version
ID:	355842   Click image for larger version
ID:	355843   Click image for larger version
ID:	355844   Click image for larger version
Old 01-03-2013, 10:36 PM
I am a rookie again
Seriously!! 107 views and not a soul has said a word???
Old 01-03-2013, 10:43 PM
bin01123's Avatar
bin01123 bin01123 is offline
Mein Auto: 2013 535i
Crankcase valve, spark plugs, and hopefully u don't need valve cover gaskets. I just replaced mine at that mileage
Sent from my HTC VLE_U using Bimmer App
Old 01-03-2013, 10:52 PM
I am a rookie again
Thanks I really appreciate it
Sent from my DROID RAZR using Bimmer App
Old 01-04-2013, 08:25 AM
Nervous Nervous is offline
Mein Auto: 01' 330CI 6MT / 00' 540i
Rear main seal, front crankshaft seal, OSV, timing chain tensioner (but you don't need to replace secondary tensioners on exhaust sprocket chains, just rebuild them with new O-ring and plastic guides), oil pan gasket (I'd do both oil pan gaskets, since engine is out). Check oil pump bolts while oil pan is out.
Old 03-15-2013, 09:52 AM
firemanory firemanory is offline
Mein Auto: 03 e39 540iT, 89 e30 325i
Why dont you need to replace the secondary tensioners? I am right in the middle of a massive overhaul but my passenger side tensioner leaves some slack in the chain. I assumed to replace it, but if I can rebuilt just as easily I am in...
Old 03-15-2013, 10:13 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Be good if you could post pics of old and new chain guides.
Old 03-15-2013, 10:18 AM
Are we talking about camshaft chain tensioners? Because they were not re-designed and you'll replace them with exactly same things = money wasted. Unless the spring is completely collapsed they do not need replacement (other than plastic guides on them and O-rings). These tensioners are oil filled (when engine runs), so it is fine if they allow some slack while there is no oil in them.
Old 03-15-2013, 11:21 AM
This is it...can I remove with just removing the bolts? How do I replace O-rings, I dont see them available to buy? Sorry, right in the middle of job now....this is the part Timing Chain Tensioner for Camshaft to Camshaft Chain (Cylinders 1-4)
Old 03-15-2013, 11:30 AM
All info is here: http://www.beisansystems.com/procedu..._procedure.htm
O-rings: http://realoem.com/bmw/showparts.do?...65&hg=11&fg=25 part #16
Old 03-15-2013, 12:11 PM
Al's540i's Avatar
Al's540i Al's540i is offline
Mein Auto: '00 BMW 540i; '11 BMW X5
Nice looking engine!
Current
2012 Audi A4 S-Line
2011 BMW X5
2000 BMW 540i
Past
2010 Mercedes ML350
1998 Audi A6 Quattro
2002 Lexus IS250
1988 Honda Prelude
Old 03-15-2013, 01:06 PM
Yeah, I'll be the original owner didn't wait 10k to change oil!
Old 11-01-2016, 11:52 PM
Mackman1157 Mackman1157 is offline
Mein Auto: 04 760, 98 540, 02 M5
Where is a good place to get a M62tu for 02-540 sport/MTech engine?
In need of a good place to purchase a whole engine due to overheating.
Mack
Old 11-02-2016, 01:58 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
yeah for a junk yard motor thats probably on its last leg as it is..
Timing,
chain, tentsioner, OSV, vanos gaskets, alternator gasket valley pan
here
Drain Plug Sealing Washer
Differential Drain Plug Gasket -
Valve Cover Gasket Set - Right
Valve Cover Gasket Set - Left
Non-Return Valve
Valve Cover Seal Washer -
Engine Oil Drain Plug -
Lower Oil Pan Gasket
Crankshaft Seal - Front
Timing Cover Gasket - With Flange
Timing Chain Cover Gasket Set - Lower
Oil Separator Valve
Center Crankshaft Bolt
Camshaft Timing Chain Tensioner
Timing Chain Tensioner Rail - Right
Timing Chain - Main Genuine BMW -
Timing Chain Guide Rail Genuine BMW -
Cylinder Head Timing Chain - Priced Each
Timing Chain Tensioner Genuine BMW -
VANOS Solenoid Gasket Genuine BMW -
Oil Filter Kit
Dipstick O-Ring
Water Pump Gasket
Cooling O-Ring -
Water Pump O-Ring (Small) - Priced Each
Alternator Gasket
Valve Cover Seal Washer - Priced Each
Upper Timing Cover Gasket - Cylinders 1-4
Upper Timing Cover Gasket - Cylinders 5-8
valley pan gasket
15486372<-----
Old 11-02-2016, 10:35 PM
LaCrosse540i6's Avatar
LaCrosse540i6 LaCrosse540i6 is offline
Smiling from gear to gear
Mein Auto: '03 540i M-sport
I would make sure the rear coolant plate isn't leaking. People often assume their valley pan is leaking when this is the actual culprit.
It's also only accessible with the transmission off so it's much easier to deal with while you have the engine out.
Old 11-03-2016, 01:49 AM
Burning2nd's Avatar
Under the lift arms
yep i did mine when i did a my clutch years back '
15486372<-----
Old 11-03-2016, 05:19 AM
mrblahh mrblahh is offline
Mein Auto: X5D, 135i, 540i, r53 *2
why replace the OSV? It's a plastic device nothing in it moves
Old 11-03-2016, 06:17 AM
computiNATEor's Avatar
computiNATEor computiNATEor is offline
(oOO\(|||) (|||)/OOo)
Mein Auto: 2 x 530i Sport
EEEEEWWWW!! Looks like the Titanic back there!
Nate J.
RIP, Seabiscuit - 03-11-03 530iA Sport, Sapphire Black/Black. T-boned 03-01-2017. 155,861mi.
Take 2 "Otto" - 04-25-2002 530iA Sport, Toledo Blue/Sandbeige. 142,000mi and counting.
Take 3 "Manuel" - 11/??/2001 530i5 Sport, Toledo Blue/Grau. 191,000mi and counting.
Old 11-03-2016, 08:51 AM
MKJS MKJS is offline
Mein Auto: '99 540iA
On the tu, the osv is under the timing chain. Mine is bad, they get old and the plastic breaks down leading to a big problem. Good thing I have to go in there to replace the guides.
Jim
Old 11-03-2016, 09:07 AM
I see no reason to do crank seals, they seem to seldom leak.
I would do the timing chain guides and osv, new valve cover gaskets and valley pan gasket whether they are needed or not. But for me, that's about all I would do.
Jim
Old 11-10-2016, 04:52 PM
berkeleydojah berkeleydojah is offline
Mein Auto: 2001 bmw 540i (sport)
The rear coolant plate and rear accumulator gaskets!!! Do this outside the car.
Old 11-11-2016, 03:12 AM
Burning2nd's Avatar
Under the lift arms
*hasn't had a brake down or really had to do must of any maintenance
remember kid's when uncle burning2nd said do it nice or do it twice... cause i wont always be around to say i told ya so
15486372<-----
Old 11-11-2016, 02:27 PM
sixpot_simon's Avatar
sixpot_simon sixpot_simon is offline
Mein Auto: E30, E39
Hahaha. Great advice!
