locked keys in trunk
So I'm on vacation in south carolina, and I've locked my key in the trunk. I've read plenty of threads, and I would be comfortable drilling a hole in the trunk, but I'm not really sure where I'm supposed to drill. It seems like everyone has heard of the concept but I haven't seen it done on an e39. I've seen the video of where it was done on an e38, but from what i can gather from realoem the locks arent quite the same. So can anyone tell me exactly where to drill? When I took off the license there was already a hole drilled dead in the center, but I havent been able to find the cable I'm supposed to be hooking, so I'm thinking it way be in the wrong place. Please help me, thanks.
I typed /unlock F3 in the bestlinks, and it came up with this, which might help you:
- How to open the hood (1) or trunk manually when you have a dead 12v car battery (1) (2) (3) & how to unlock the older E39 if the key is locked inside the trunk (1) (2)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Sorry you're going through this...but this is just another reminder to NOT keep your trunk lock cylinder in the VALET mode ( -- )...and when you only have one key (available)...to ALWAYS leave the trunk lock cylinder in the vertical position ( | ) as well as ALWAYS unlocking the door when going to the trunk. That way, if you do accidentally slam the trunk closed with the key inside, you can ALWAYS gain entry to the trunk to retrieve the key. The central locking system is always UNLOCKED following this procedure until you physically relock the car with the key when you're done.
![]() Just when you think it won't happen to you...it will.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
Man.. I remeber this happening to me.. when I was local... I locked the doors and like an idiot I went to the trunk to get something .. while looking for that something.. I layed the key in the trunk... after I got what I needed.. you guessed it.> I slammed the trunk shut and I was like.> OH FUK!!!. ... luckily my sister lives close by.. called her to get my spare keys at home.. and drove over and pop goes the weeesel lol...
anyways... you got some options I guess.. Bust the window ? call a lock smith ? or if you have spare keys.. have them send it to you.. depends how desperate you need the car.. but... there is no way you are getting that key out without doing something you dont want... GOOD LUCK and let us know what you did to get out of this jamm |
Go to local dealer and order a key for $45, it will take proof of ownership and 2-3 days.
Guys please, save the lectures and other suggestions. All I really care about at this point is where do I drill? Thanks.
Dude, did you bother to read what bluebee posted???
I copy and pasted this for you.... hi ......ok do you have 2 holes behind your licence plate to where you attach your licence plate via screws.....if so then from the right one in a dead straight line approx 7 cm away going to the right drill a hole approx 0.5cm in diameter once your through the metal plate behind the bodywork insert a small piece of wire but something quite rigid and just try to locate the rod that connects from the boot (trunk) lock in which you insert your key to where the actuall lock is between the boot (trunk) and the body of the car, once you move that, it will pop the soleniod open.....the reason for the sticky pad is that here in the uk we dont use the screws to hold the licence plate as it spoils the look instead we use very strong adhesive pads so what i maent was after you finished you would just apply one of these over the hole and it we never even be seen again....hope this helps.... |
No worries, I figured it out no thanks to yall.
Here is the tool you need, they can be found at all good building supply stores:
![]() I guess you could also go in via the rear tail light and try to retrieve the key? |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
