Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 08-20-2010, 01:11 PM
E38gurl E38gurl is offline
Mein Auto: 1995 740i
Smile E38 front right turn signal assembly a DIY job?
I've found the replacement part, but don't want to screw it up. Anyone done this before and can shed some light? Thanks in advance
Old 08-20-2010, 02:01 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Open the hood and look for a small plastic cap over a hole in the lip that looks like a 'rain gutter.' Remove the cap and use a Phillips screwdriver to loosen (not remove) the screw that's down in the hole. It's a clamp, so you only have to loosen it.
Slide the corner turn signal forward, unplug, swap.
(Photos from e38.org)
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 09-03-2010, 10:08 AM
Thank you so much for the easy to follow pictures. I realize now this was simple and I feel quite accomplished having avoided paying someone else to repair! My first DIY and from what I'm reading in other posts, it won't be my last!
Blessings!
Old 01-03-2013, 07:17 PM
RJK740iL RJK740iL is offline
Send a message via AIM to RJK740iL
Mein Auto: 2001 740iL
Plan B- exchange turn signals
your instructions were simple and straight forward enough. I got the amber lens that I want to use instead of the clear one that's on the 2001 740iL now. Found the hole, inserted the screwdriver, bumped into a few "other" wires or parts. I think I found the screw, and turned it approx 10-11 times, as per some other person suggestion, and it did not come loose. I didn't wanna go past the suggested number of turns, as I read that the screw mount will come out of the socket. But since I couldn't get the lens out after that number of rotations, my plan B is that I DO go past the 11 rotations and hopefully 2 things will happen. 1- the lens will come out and 2- the screw mount will also come loose. The questions is - will I be able to re-screw that part back into place, and subsequently be able to tighten the new amber lens in place ? Is my plan B do-able ? Or do you have any other suggestions.
Current
2001 E38 740iL Orientblue / Beige
Prevous
1995 E38 740i Silver/Grey
Old 01-03-2013, 07:59 PM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
The 'lense' is a whole lamp unit. The only problem in fully undoing the clamp is that a part will fall off and have to be found and part screwed back B 4 you refit the new unit. Are you pressing down too hard on the screwdriver handle? You may have stripped a thread in plastic. Try turning with the lightest possible downward force possible. Tip for young players: When refitting a self tapping screw into plastic part turn the screw backwards first to feel where the existing thread starts. Try not to start a new thread as you will run out of plastic as the hole increases in size as plastic is cut away by the screw.
Current:
Previous:
Old 01-04-2013, 09:12 AM
different headlight ??
I tried again this am. The thought occurred to me that the passenger turn signal/headlight may be a different model than the driver's side. The previous owner did have a small accident on the passenger side, and the "headlight" was changed to the clear version. I have seen some of these headlight/turn signal lights, are they an "all in one" type, and would I be able to remove it the same way as a non-all in one, or do I need to remove the entire headlight to change (if at all possible) the turn signal. I stuck the screwdriver in the drivers side to see what the screw "felt" like. It was very easy to access, and I found the screw head almost immediately, that's not the case with the driver''s side at all. Wadda think ?
Current
Prevous
Old 01-04-2013, 09:24 AM
setconstr setconstr is offline
Mein Auto: 2001 740i sport 2006 m6
re
take a flashlight and look down the hole you can see the screw it does not matter if you un-screw it all the way and the clamp falls out it will fall down inside the bumper cover and you can take your foglight out reach in and find it
2001 740i sport, Dinan upgrades, Bilstein's & H&R 2's , Zimmerman vented rotors, Akebono pads, HID fogs, BSW speakers and subwolfer, MKIV nav, Alpina Lip, OEM clear lights, 3m carbon fiber interior wood delete, 20" BBS, Fast enough for me
Old 01-04-2013, 10:37 AM
plan B- sounds good
will try and find the screw, and loosen it completely... tks
Current
Prevous
HTML code is Off
