Old 01-04-2013, 09:24 AM
Fresh1107 Fresh1107 is offline
Mein Auto: 2004 745LI
2004 745Li Transmission Failsafe
Hello everyone. I'll start off by saying thanks in advance to anyone who can shed some light on my issues. I've found this forum to be a great source of information when it comes to these beautiful cars.
My car is a 2004 745Li with a transmission issue. I've had it for about a year now and it's always shifted a little rough. Worse when cold. When driving down the highway and in 6th gear it will randomly slip out of gear and rev up about 1000-1500 rpms for about 2 seconds and go back into gear. On occasion it will be bad enough to bring up transmission Failsafe on the dash and then it won't even go into 6th gear. Lately when starting the car, I'll put it in gear and it will automatically say transmission Failsafe and refuses to go into drive or reverse. Please help. Awhile back I had changed the integrated supply module in hopes that it was part of the issue, but no luck there.
Old 01-05-2013, 02:47 AM
I would also like to add that less than a year ago I did replace the battery and alternator.
Old 01-05-2013, 08:17 AM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Hi,
Quite a common problem, the transmission has detected a fault and shifted to 'Park' to prevent damage to itself. It is likely a low oil pressure issue caused by low fluid level or a cracked bridge seal between the mechatronics valve body and the oil pump inside the main body of the transmission.
If you can get hold of INPA read the error codes from the EGS module and post them up, I would suspect you have 'Gear check errors' where the transmission is slipping.
I had this issue, sometimes I could put the car into 'R' and hit the gas and it would go forwards! Issue was the low oil pressure not being able to apply enough pressure to the clutch packs.
The bridge seal design has been revised by ZF to make it more robust.
Stuart
2008 F01 - Sophistograu with Saddle Brown Leather
Retrofits:
Night Vision, Digital TV, Heated M-Sport Steering Wheel + Paddles, Combox, 6NF Baseplate, 6NR Apps, Rear Entertainment System, Automatic Boot Close and Surround View Cameras.
Old 01-05-2013, 11:24 AM
Thanks Stuart. I'm going to look into that. Was this something that you were able to fix yourself? I'm a very good mechanic, but the bmw transmission isn't my specialty. I appreciate any response.
Old 01-05-2013, 11:45 AM
Mein Auto: BMW F01
No problem!
It's not that difficult, just take your time, if you have some ramps like at a workshop or something then it's really easy!
My trans finally blew on the way home, luckily I managed to limp it back to my girlfriends house! As soon as I took it out of drive it would stay permanently in park even when cooled down, these cars are seriously heavy to be pushing around!
I ended up pulling the pan and mechatronics in the parking space.
Here are some pics:
Pan and mechatronics removed
Mechatronics in the kitchen!
This was the cause of all the problems, this is almost certainly what's wrong with yours.
This is the valve body with the electronics module removed, notice the grey film? This is debris from the clutch packs, it's conductive and can cause issues with the speed sensors. It's worth cleaning as much of this off as possible.
Makeshift shelter! It was raining!
New seal fitted
My mate helping me refit it!
The seal itself costs around 5! A cheap fix to an otherwise very expensive transmission problem!
I have heard this and the connector sleeve an leaking oil pan are the three most common problems, a local ZF specialist has confirmed these boxes come back for repair and these are the issues they all have, very rarely does anything mechanical go wrong with them. The mechatronics is pretty intelligent and will go into failsafe immediately if something is wrong to avoid causing internal damage. It may be a nuisance but at least it's not wrecking itself!
Hope this helps, any questions just ask.
Stuart
Retrofits:
Old 01-06-2013, 03:04 PM
Wow. Thanks Stuart! I couldn't have asked for a better or more detailed response. I'll get going on this immediately. I'll let you know what I come up with.
Old 01-06-2013, 03:13 PM
Where can I go to get the bridge seal Stuart?
Old 04-06-2013, 06:27 PM
Hey Stuart, just wanted to update you and say thanks for all of your help. Turned out that I had an oil pressure issue. The previous owner of my car did some not so professional repair work to a leaking transmission line. Long story short, I fixed it myself and I'm doing good so far. Thanks again.
Old 04-06-2013, 06:50 PM
christpatillo christpatillo is offline
Send a message via ICQ to christpatillo
Mein Auto: bmw
Old 11-21-2013, 06:39 PM
Re: 2004 745Li Transmission Failsafe
Hello Stuart. Its been awhile since I've spoken with you. Hope everything is going well for you. I'm having some issues and I'm wondering if youve got some input. I recently changed my bridge seal and sealing sleeve due to transmission failsafe and recently transmission fault occurring. After replacing both of these parts, the fault is still present. Do you know if I need to have these faults cleared before the car will recognize that the repairs were made? Any thoughts?
Sent from my Nexus 5 using BimmerApp mobile app
Old 01-29-2014, 10:14 AM
silverb silverb is offline
Mein Auto: 745i
Finding this thread saved me buying a new transmission. I asked my mech to try replacing the bridge seal and replacing the leaking pan, it corrected the code for the clutch 5 and stopped the 5th gear prob, the park gear fail, and the failsafe.
Old 02-24-2014, 09:39 PM
ericesquire ericesquire is offline
Mein Auto: 2004 BMW 745Li
What is the "5th gear problem" you speak of? Surge under steady throttle pressure?
It's the last issue with my 2004 745Li and I'm dying to figure it out.
Just fixed the infamous coolant transfer pipe leak. Really happy about that and hungry to make it "perfect" again.
Old 01-15-2015, 02:32 PM
astro_ astro_ is offline
Mein Auto: 745li
I have a low pressure issue with my 745 what did you to fix that on your car
Old 08-22-2015, 04:07 AM
Tazrojas Tazrojas is offline
Mein Auto: 2003 bmw 745i
hard gear changes from 1-2.
Hi guys I think I might have the same problem. I took my car to the mechanic and he told me I had to replace the whole transmission and that it was going to run me above the $5000. I just got my car on January of 2015 and have spend $2500 fixing issues here and there. I just don't want this car to be a super money pit.
How much did you guys spend replacing the seal and for the low oil pressure? Can any of you guys help??? Sadly today my car gave me the flirts transmission fail safe and I couldn't move back or forward. I had to turn of the car and turn it back on. And it let me make it home.
Old 09-17-2015, 06:40 PM
sonyalynn36 sonyalynn36 is offline
Mein Auto: 04 745i
Hello everyone! I got my car in Feb 2015 and I seem to be having the same problem. It won't go into drive or reverse when trying it goes right back into park also it's saying transmission fail safe. Been sitting for 4 days and towed it to a transmission shop. They said there's nothing wrong with the transmission and the guy reprogrammed it to clear some codes. Paid and drove it home transmission fail safe 4 hours later. It will drive but transmission fail safe stays on so I don't drive it. Does anyone have any advice so I don't spend unnecessary time and money with a shop that doesn't know what they are doing?
