Old 01-04-2013, 10:14 AM
Blkmamba1 Blkmamba1 is offline
Mein Auto: 2012 335is
Wheel problem
I just went to install my winter tire/wheel that I purchased from tire rack..bought sport edition A7 black 17" with Bridgestone blizzak...but the technician couldn't install them due to hub diameter issues. Has anyone had such issues? I confirmed this with tire rack sales associate before purchasing them! Any recommendations?
Old 01-04-2013, 10:27 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
do you run stock or aftermarket wheels for the summer?
you may have a hubcentric ring still stuck on the hub if you run aftermarket.
they should fit-- the A7 for BMW comes with the correct centerbore and takes stock lugs and caps. all bmws aside from two models use the same centerbore for the past 15+ years
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 01-04-2013, 10:32 AM
No mine are the original/stock 18" style 313 from the factory. Tire rack recommended minus size for the winter. Do I need to get the 18"? Would that make a difference?
It's for 2012 335is
Old 01-04-2013, 10:38 AM
It's for 2012 335is
the 335is has the same brakes as the regular 335i, so the 17" A7 should fit-- at this point call the tire rack
my 2010 and 2007 335i's had no issues with 17" wheels
Old 01-09-2013, 07:54 AM
FYI the 335is hub diameter is different, apparently it measured at 73.02mm compared to 72.5mm. Tire rack was able to send me new wheels/tire and they look amazing!!! I will post pic later.
Old 01-09-2013, 08:05 AM
thats bizzare, the hub for the 335is is the same as the non IS, in fact, the part is used on quite a few other cars.
Part 31216765157 (Wheel hub with bearing, front) was found on the following vehicles:
E82: Details on E82
E82 128i Coupe
E82 135i Coupe
E82e: Details on E82e
E82e eDrive 1 Coupe
E84: Details on E84
E84 X1 28i SUV
E88: Details on E88
E88 128i Convertible
E88 135i Convertible
E89: Details on E89
E89 Z4 28i Roadster
E89 Z4 30i Roadster
E89 Z4 35i Roadster
E89 Z4 35is Roadster
E90: Details on E90
E90 323i Sedan
E90 325i Sedan
E90 328i Sedan
E90 330i Sedan
E90 335i Sedan
E90N: Details on E90N
E90N 323i Sedan
E90N 328i Sedan
E90N 335d Sedan
E90N 335i Sedan
E91: Details on E91
E91 328i Touring
E91N: Details on E91N
E91N 328i Touring
E92: Details on E92
E92 328i Coupe
E92 335i Coupe
E92N: Details on E92N
E92N 328i Coupe
E92N 335i Coupe
E92N 335is Coupe
E93: Details on E93
E93 328i Convertible
E93 335i Convertible
E93N: Details on E93N
E93N 328i Convertible
E93N 335i Convertible
E93N 335is Convertible
