E34 (1989 - 1995)
Old 01-04-2013, 02:12 PM
tchat48 tchat48 is offline
tchat
Mein Auto: 1990 525i
1990 525i NO HEAT!!!!
i know tht the resistor or "sword" has been removed. is there any way to get around tht just so i can have some kind of air flow thru my vents.????? or does the sword have to be installed?
Old 01-04-2013, 02:24 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I'm pretty sure the sword has to be installed to have the blower run. Someone may know of a direct wiring trick to make the blower run
One option is to make sure that the recirculate button is not pressed, and raise the back of the sunroof. This creates a venturi effect and draws more air through the vents. It will give you just a bit more air flow. Just make sure that all of your controls are all the way to the hot side. I do this during the spring and fall with the temp set to cold to draw in slightly cooled air if I don't want to run the A/C.
Hope this helps.
Where in NC are you?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-04-2013, 08:38 PM
virgontour virgontour is offline
Mein Auto: 535i
is there any air comming out of the floor, windscreen demister, or even under dash some were ect......... if so easy as pie !
