Old 07-22-2004, 04:26 AM
CMWalker CMWalker is offline
Mein Auto: 99 M Coupe, 02 530i
Body Electronics Control Module Location and P/N?
I posted on Roadfly too. Awaiting any response...
Symptoms: Dead short across fuse 33, interior lights.
Troubleshooting: Removed all load from circuit, still short.
Suspect: Body Electronics Control Module
Need to know: Location under hood (believe passenger side fender)
Like to know: BMW part number (in case I have to order it)
Thanks Everyone
Old 07-22-2004, 02:42 PM
Ron Stygar's Avatar
19,585 Miles
Thanks Everyone
The ZKE-IV is behind the glove box. Part number 61 35 8 387 530. $333.00 retail.
What makes you think that it is the ZKE-IV?
Old 07-22-2004, 07:29 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
In my roadster, the most prevalent cause of blowing that fuse is the trunk light. Mine doesn't stay in well, and the contacts aren't really protected from the sheet metal in which it's inserted. More than once when it has popped out, both contacts have come to rest on the sheet metal (short). I've since taped the contacts with silicone splicing tape and put a small piece of teflon electrical tape on the sheet metal where the contacts like to hit. No idea what lights the coupe may or may not have with similar issues.
Daniel
2002 M roadster
Old 07-23-2004, 05:16 PM
StevzZ3's Avatar
StevzZ3 StevzZ3 is offline
Analyzer Tech.
Mein Auto: 2000 Z3 , 3/blk.
short
Have you looked at the wire going to your lighted shift knob? Just a thought.
Good Luck,
Steve H.
2000 Z3
SchwarZ II x III
Old 07-23-2004, 06:26 PM
Ron Stygar's Avatar
19,585 Miles
Good Luck,
Steve H.
That is fed from fuse 37.
Old 07-23-2004, 07:30 PM
Randy Forbes's Avatar
Investigative Tinkerer
And we know that it would take out the rheostat in the headlight switch before the fuse can blow. Great bit of engineering, that
Randy Forbes
2001///M Rdstr Steel Gray
Old 07-24-2004, 03:58 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
Can you make the electronic dimmer control from a regular body E36 fit in a Z3? It appears to be short circuit protected.
Old 07-24-2004, 04:25 AM
Reasons for suspicion
First off, I'm not much of an electrical guy, so my buddy who is was helping troubleshoot. So if I'm wrong, HE'S the fool! (j/k. He's a great guy)
We were led to the control module because all attempts at isolating individual loads on the circuits still left us with the short. There could be frayed or chewed wiring somewhere I suppose, but we saw no evidence of that.
My dealer tells me that the module is also an unlikely suspect, and that the cost is $330 just for the part. But even if I buy and install it, it has to be "coded" to identify the vehicle. And that can only be done by the dealer.
Thanks for the picture. That might help further testing. Meanwhile, I miss the simplicity of my E30. Course, the power of the Coupe helps me forget!
Thanks for the help.
Craig
Old 07-24-2004, 05:01 AM
johnf's Avatar
John Firestone
I am not sure I understand. Did you try unplugging the ZKE (including the connector, X13252, on its backside ) and was the short still there?
What I find helpful for finding a parasitic short is to place a fairly large power resistor in series with the fuse to keep it from blowing (I use a couple 15 ohm 5W resistors in series) and then check the current through the wiring using a clamp on (hall effect) DC ammeter.
Note that the ZKE will start to draw current as soon as you unlock the car or open a door and will continue to until it goes back to sleep. This man's non-Z3 remains awake for some minutes after closing the doors and locking the car.
Old 07-24-2004, 06:57 AM
Yes, it would be easy enough to do, if one was so inclined. You would have a separate control for dimming, but it's easy enough to find the connection points on the headlight switch. Since I always use those lights at full brightness anyway, I just jumped across the rheostat terminals.
Randy Forbes
Old 07-24-2004, 10:45 AM
Well, we never knew exactly where to FIND the controller. We just saw it on the schematic. Thanks to the info I got here, we should be able to do exactly what you're saying.
I'll pass on the resistor/ammeter trick to my buddy. I have a pretty good idea what you're suggesting, but he'll know exactly what you mean.
Old 07-24-2004, 12:23 PM
johnf's Avatar
John Firestone
Sorry, I suffered a little temporary brain fade. The black connector on the back that is hard to reach is X10182. The ETM I am looking at shows continuous power to its pin 18 through fuse F2, not F33. Fuse F33 feeds X13252 which should be the big, hunky black connector on the front.
The ZKE must have been designed by committee: the latter would have been sufficient to handle the power.
Good luck in your troubleshooting!
Old 07-24-2004, 03:55 PM
dwm's Avatar
dwm dwm is offline
Not having taken the ZKE apart, I've always assumed that things like F33 only feed high-side drivers, and were fused separately so you didn't knock out the whole ZKE when shorting a lamp circuit. Of course, the ZKE isn't of much use w/o the high-side drivers on F33 if the sun isn't up.
Daniel
2002 M roadster
Old 07-24-2004, 04:12 PM
johnf's Avatar
John Firestone
The ETM claims there are not 2 but 34 fuses that provide power to the ZKE at all times:
  • F2 - if car has an M43 or M52 engine
  • F14 - for the power windows
  • F33 - for the interior lights
  • F35 - for the central locking
