BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Google/Panoramio/Street Viewer missing in BMW Live
Hi guy,
Need some kind assistance here. |
Apologies guys, press submit too fast.
As per topic, I had gotten my 2012 F10 enabled with BMW Live by a coder as per attached: But seems that the Google Local Search, Panoramio, Street Viewer is missing as per showcase by others: Wonder if anybody have such experience & kindly point out what might be the missing code so that I could get the coder to perform the necessary? Appreciate. Last edited by DTee; 01-04-2013 at 08:57 PM. |
Is you Phone Paired with a working Internet over Bluetooth connection?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
is bmw live only available outside of the U.S? Possible to code it inside of the U.S?
See my Post here: http://www.bimmerfest.com/forums/sho...6&postcount=70
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 01-04-2013 at 11:06 PM. |
Is the VIN attached to anything else? That doesn't seem like that big of a deal but I am wondering if I would lose features if I used a Vin of a car that doesn't have the same options as mine.
No, you loose nothing except BMW Assist, which for me I hated loosing only because of the Google Send-To-Car feature.
Does that mean I lose the SOS button too? Isn't that part of assist? Not sure if it's worth the safety risk.
No. SOS is the exception. That will still work.
Where would be the best place to find a Vin with 614 and 615?
Off the VIN Plate of a Malaysian F10.
![]() I have PM'd one to you.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 01-04-2013 at 11:39 PM. |
Any other possible thoughts? Possible with mistake in coding? I had also performed the setup & received an acknowledgement email from BMW. Was told to set the country & region to Europe - Germany. Thanks. |
ONLINE_BROWSER_LIVE ONLINE_SERVICES ONLINE_SERVICES_GLS
But on the other hand, if I don't have these values, my BMW Live weather, news, & Internet shouldn't be working right? Does the speed of BMW Live plays a part too as the current setup is very slow even tethering with LTE network. Thanks. |
Speed is no issue. I used BMW Live with a tethered Verizon 3G Blackberry.
Choose another country in Live Setup!
Thanks Shawn! I am going to try it out today.
As I already said, change your country in BMW Live to another one. If I choose Belgium, neither google nor StreetView is available. When I switch over to Germany, everything shows up and is working.
Do this: Connect => Read FA => Activate FA => Read VCM => Left-Click on CMB_MEDIA => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on CMB_MEDIA (the ECU itself not the underlying CAFD) => Select CODE. To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps. The I-Step (current) is the one you want to match when you select the CAFD from the "Detect CAF for SWE" options (e.g. F001-08-09-550).
Hope for the best & will update everybody accordingly. Thanks. |
Whats weird is that my fa never had 612, 633 or 639. Is it possible there is a different number for bmw assist? I also seem to be getting this error when VO coding HU_CIC cdDeploy ProcessedWithError cafd_000000f9-007_003_022 ProcessedWithError The error went away wend I added 616 to VO UPDATE----- I activated live and internet (forgot about that) I click on live after updating services and it says service not available I click on internet and it says other bmw assist options are enable. (dont remember the exact wording) Last edited by djsaad1; 01-05-2013 at 01:45 PM. |
What is your Bluetooth Option code? You should have 615 not 616 in your VO: S615A Expanded BMW Online Information S616A BMW Online Do you have both in there now? Do you have an CMB_ECALL module in your SVT?
car is an f06 650i I didn't have 615 or 616. When I added 615, VO coding HU_CIC would give me an error, if I removed 615 or added 616 the error would go away. I do have a CMB_ECALL module. |
#25
Since you have CMB_ECALL, you have a Telematics Combox (BMW Assist). Your Bluetooth code is likely 6NL BMW Assist with enhanced Bluetooth and USB. You have to kill 6NL and replace it with 6NK is my guess, and then replace 616 with 615.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 01-05-2013 at 06:42 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
