Old 01-05-2013, 12:10 AM
vino007 vino007 is offline
Mein Auto: 135i
FS: Stett Charge Pipe w/ Tial Blow off Valve N54
Selling my Stett Charge Pipe with Tial Blow off Valve reg 600$ + shipping + taxes
i am asking for 350$
it is used but in perfect working condition
i am from montreal but i can ship anywhere...
for 135i / 335i N54
514-247-8466
Vinh
also selling JB4 and Active Autowerke Downpipe
Item #: SP11-220180
The factory plastic charge pipe and diverter valves are prone to leaking under stock boost levels, increasing boost only makes this problem worse. The stock diverter valves are not designed internally to handle added boost pressure. They can fail under load which will actually cause boost bleed off when you don't want it causing boost spikes and loss of horsepower. The STETT Performance N54 135i/335i charge pipe is made from 100% 304 stainless steel and designed to handle higher than stock boost levels without leaking thanks to it's very strong design, ultra high quality materials and our patent pending throttle body connector that forms an ultra tight seal and prevents the charge pipe from blowing off as is so common with other products on the market. The factory plastic piece begins to leak on even stock level boost. Simply using a standard silicone hose connector to connect an aftermarket pipe leaves a high chance the pipe will blow off the engine. We, however, developed a patent pending 4 ply, double layer hose connector to the throttle body which is far superior to anything else on the market including the factory flimsy o-ring and lock clip. Each kit comes with everything you need for installation including the billet aluminum BOV from Tial, one of the most respected names in the industry. Each pipe comes standard with dual stainless meth bungs.
Proudly made in the U.S.A.
Sound Clip: HERE
- 304 stainless steel replaces factory plastic
- Ultra high quality and strong materials
- Eliminate leaks caused by weak factory connections
- Get back horsepower lost from weak factory diverter valves
- Our patent pending hose connector eliminates pipe from blowing off engine under load
- Dual stainless Meth bungs
- Extreme Duty silicone hoses
- High strength stainless hardware
Old 06-09-2013, 05:38 PM
SoFresh&SoClean SoFresh&SoClean is offline
Mein Auto: 2010 535i Xdrive
Still have charge pipe for sale? Can I use on my 2010 535i xdrive? I'm going to install JB4 with dci soon and wonder if this would be useful...thanks
Old 08-28-2013, 03:53 AM
Sinkas Sinkas is offline
Mein Auto: 2006 335i
Still for sale any chance of a bundle price and shipped to aus?
Old 09-23-2013, 04:06 PM
Paul Ferd Paul Ferd is offline
Mein Auto: 2008 335i coupe 6MT
Still available?
2008 335i coupe
6MT, DCI ONLY
13.45 @ 103.1
Old 09-23-2013, 05:10 PM
Slvr335 Slvr335 is offline
Mein Auto: 2008 Stage II 335i
+1... Pm me
Old 04-24-2014, 11:41 AM
Miceli Miceli is offline
Mein Auto: 2007 335i
is this still available?
Old 04-25-2014, 09:05 AM
super95six super95six is offline
Mein Auto: 08 335 Convt
Sounds like I missed the party but if you've still got both or either I definitely want them.
