E34 (1989 - 1995)
Old 01-05-2013, 06:45 AM
Cyberjoppe Cyberjoppe is offline
Mein Auto: 525i -94
half and driving lights errors
Hello my name is Jonas and i am from sweden.
So my english is bad but i hope you can understand me.
Okey, I needed help with a small matter.
I wonder if there are any relay that controls the lights on the coulter.
I have a bmw e34 525i kompi -94.
During Vallåkra weekend killed my lights on the car, first started low beam die and then full light.
I finally got hold of a LKM box with the same number as my last.
but when I change this today, it still does not work.
Does anyone know here what might be the problem maybe?
grateful for a response to the survey will in February
MVH
Old 01-05-2013, 05:11 PM
Mein Auto: 1989 525i M20B25
Did you check your fuses?
Old 01-05-2013, 05:28 PM
Mein Auto: 525i -94
Yes the fuses are okey.
Old 01-05-2013, 07:37 PM
So the lights themselves are not working, AND you are receiving a message on the dashboard? One or the other, or both?
Old 01-05-2013, 07:45 PM
Mein Auto: 525i -94
Exactly. But i receiving no message at the dashboard. The lights only died one after one :/
Old 01-06-2013, 09:11 PM
BMWFatherFigure's Avatar
Old School
Check all the vehicle earths on dash, light control module and everything else you can find. Also check loom plugs as you work through for clean and tight. Starting with changing the expensive bits is not always the best. You wrote that changing the module did not fix it so I would guess it will be a simple fix else where on the car.
Current:
E38 Parts Car
Previous:
