Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
3 Series
The 3 Series Forum. If you would like to see all new posts in all the forums, click here. |
BMW Antifreeze VS TOYOTA RED antifreeze
OK, I know I sound a bit crazy, but I am not convinced about the 50 water / 50 BMW antifreeze mix thing.
I 'll tell you why. Every time I go to my specialist, I see one car that has either had cracked gasket, blocked cooling system, etc. The answer I get is: "This is what water does to the engine. It slowly eats the alloy up with electrolysis, causing this to happen eventually. Now, my car has had the original BMW factory thing for three and 1/2 years. I have just changed it recently with the 50% BMW antifreeze / 50% Table filtered water. I must admit, I have never seen TOYOTAS having this kind of problem. It must be down to theit good quality antifreeze. This is it. It must not be mixed with water. This thing is said over here(unoficcally) to be the best. It is said to last for 100k miles! It is expensive though. Comes in 4l bottles and costs 25$ the 4l. I am thinking of switching my BMW with this thing. Toyotas engines are all alloy, as well as BMWs engines. ![]() Genuine Toyota Long Life Antifreeze Coolant, with its distinctive red appearance, provides maximum protection without the use of harmful silicates. This formula is extremely durable and because of its compatibility with non-metallic materials, it helps extend the life of water pump seals. Genuine Toyota Long Life Antifreeze Coolant is the same high quality red fluid that's found in all new Toyotas. Its unique formulation was developed exclusively to meet the specific requirements of your Toyota engine. Other benefits to using Toyota Long Life Antifreeze Coolant are:
Toyota recommends Genuine Toyota Long Life Antifreeze Coolant (factory red fluid) as the first choice when maintaining your vehicle. Toyota coolant was developed to meet the specific requirements of our engines and provides maximum protection without the use of harmful silicates. Silicates, a main ingredient in the vast majority of antifreeze coolants, can actually damage the water pump seal, causing leakage. Our coolant is a high-performance, non-silicate coolant that provides better protection for metals without deterioration of the water pump seal. Genuine Toyota Long Life Antifreeze Coolant is available at your local Toyota dealership. |
MMMMMmmmmmmmmmbut Toyota's have problems with motors getting destroyed by sludging of the oil, regardless of the use of conventional or synthetic?
Maybe Cyprus is different in terms of the water people use, but using 50/50 BMW AF and distilled water, I've seen people going hundreds of thousands of miles on BMW engines with regular coolant changes and system maintenance. What I do see is that BMW has relatively short-lived water pumps. If one does not change water pumps at 60-80K miles preventatively, they are begging for overheating problems. And overheating problems lead to blown headgaskets and warped and cracked heads. As far as the Toyota AF, it's probably just pre-mixed down to a 50/50 mixture, ready to use. Much easier and more accurate than making your own mix, to be certain.
--Micah O'C CCA 193374 '04 ZHP, Jet Black 6spd, hot seats, Xenon Strut/SwayBarbarians, PowerFlex CAB/TAB, 3.38 LSD |
Um, all coolants have water in it. It's just a matter of whether it has less of it in the bottle (concentrated) or more (ready-to-pour).
Japanese coolants have different checmical content than european coolants, and mixing or substituting may cause abnormal problems with components.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline 1988 M6 Royalblau/Silbergrau Nappa |
The way i understand it is that water has very high thermal capacity, meaning it can absorb a huge amount of heat. You can use alcohol as coolant if you can supply large enough quantity and at a fast enough flow rate. But it's impractical in automotive application. Pure 100% alcohol or other chemicals are used as coolant in industrial applicaitons, but water is a good choice coz it's cheap, stable and non-toxic.
I'm thinking that your problems may lie with the water. I've seen enough people go for a long enough time on BMW coolant - and seen first hand what off-the-shelf coolants did to the coolant system on my 325e - that I'm sticking with BMW coolant. But it is hard if you don't have access to water that you know is decently pure. Thought about setting up a home still?
"This is a revolution, dammit! We're going to have to offend SOMEbody!" |
I dont think that it is good to compare the toyota item with off the shelf products.
I tihnk it is not by luck that TOYOTAS are rated the most reliable cars in the world. Yes, they are excellent engineered, but so are BMWS. I think the excuse of an expensive shipment of ready mixed coolant fluid is quite cheap, to say the least. If Toyota can do it, I am sure BMW can do it, which is a more upmarket vehicle manufacturer. I think the reasons are much more dark. The more oxidisinfg agents you have in your engine, the sooner you will need to have a re-builf of some sort. DADA!!! More money for BMW. A Head gasket for a 2.2l 320i (M54) costs 2000$ almost here in Cyprus. I would imagine in the US the price to be around $1.000. Now, having seen so many vehicles suffering from this failure, and knowing for sure that this pre-mixed fluid is the best, I will definitely put it in my BMW engine. And I bet you, it will be far better than the 50/50 mix, and even the distilled water mix. I mean, for Gods sake, BMW main dealer puts TAP WATER mixed 50/50 with antifreeze. DO YOU KNOW WHAT TAP WATER IS HERE IN CYPRUS??? It is De-Salted SEA WATER!!!!! Yes. De-salted sea water. Due to the lack of rainfall the recent years, the GVMT has installed these plants, which de-salt the sea water. That is what the main dealer and most mechanics(Well besides Honda and TOYoTA here in Cyprus) put in their vehicles. And gues who has the better rates regarding reliability over here?? 1. TOYOTA 2. (Really close HONDA) Now, who said that BMW antifreeze is a good choice???? Oh, yes I forgot. BMW DUBAI uses BMW pre-mixed antifreeze from the factory.I know cause the GM is Cypriot and he told me. So this product really exists.......What is the Part number????????? |
Still to my question: My car now has 50% drinking water in it, 50% coolant. I think this is not really good. Well, at least it is not sea water!! Coming back to my question......do you think the premixed toyota antifreeze will be good to use in a bmw 6 cylinder alloy engine? |
Read up about what happens to VW VR6 engines when you switch from 'old' VW coolant to 'new' VW coolant. THey are BOTH VW coolants. But you switch it wrong and it will destroy the motor. Like I said before, the makeup of Japanese vs european coolants is different. BMW specifically states that their coolant must be NAP-free (nitrite/amine/phosphate). But Japanese coolant almost universally has high doses of phosphate. On the other hand, european coolants have silicates in them whereas Japanese ones have none.
"Genuine Toyota Long Life Antifreeze Coolant, with its distinctive red appearance, provides maximum protection without the use of harmful silicates. This formula is extremely durable and because of its compatibility with non-metallic materials, it helps extend the life of water pump seals. Genuine Toyota Long Life Antifreeze Coolant is the same high quality red fluid that's found in all new Toyotas. Its unique formulation was developed exclusively to meet the specific requirements of your Toyota engine. Other benefits to using Toyota Long Life Antifreeze Coolant are:
Oh, I forgot, radiators and water pumps will fail eventually, anyways. Cannot blame it onn the coolant... |
i think changing engine oil more frequently do more for your engine than any improvement you can find switching among Toyota, BMW and self-mix 50/50 coolant.
So, whats your point? |
Anyways, does the colour has anything to do with it??? Why is it that european cars must not use NAP collants, where japanese must not use silicates coolants>?? especially since both toyota and bmw engines are aluminium? |
Genuine Toyota Long Life Antifreeze Coolant, with its distinctive red appearance, provides maximum protection without the use of harmful silicates. This formula is extremely durable and because of its compatibility with non-metallic materials, it helps extend the life of water pump seals Every manufacturer would say its coolant provides maximium protection and is extremely durable. Afterall, most people can't tell the difference in performance without a lab.
I'm not a chemist or metallurgist, but I'm willing to bet that each manufacturer (hopefully) picks materials and coolants that are compatible with each other. That's not just the engine and radiator, but includes gaskets, hoses, water pump components, thermostats, etc. And radiators are no longer made of one material, either. And 'aluminum' isn't pure aluminum, either. They're all alloys, and those other alloying materials may react differently to different chemicals. Go ahead and use what you want. But you've been warned. And if something happens because you decided to switch, you don't have anyone else to blame.
Now, my car has 50% filtered drinking water, 50% BMW antifreeze. How bad can that be? |
Feels like I'm talking to a 6-year-old.
Use DISTILED or deionized water. Not tap, not filtered, not Disanti...
Even quality filtered water has some harmful stuff in it...
07' 335I, Sapphire Black, Sports Pkg, Premium, Cold, Sat. 04' 330Ci Electric Red, Sport Pkg, M3 STB. (Traded in) 03' HD Softtail 06' KTM XC |
BTW, you didnt state that the TOYOTA antifreeze has these materials in it. -nitrite/amine/phosphate- You said BMW reccomends non NAP coolants. So, 1. is the TOYOTA RED one with, or without these materials??? Kaz, feel free to point ANY other thread that you think I acted as a 6 year old as you say, and repost it here on this thread. Anyways, this conversation with you and me is over for my part. I guess forums are like the real world,there are good guys, and there is always the occasional jerk. P.S. Will someone who knows about the TOYOTA antifreeze help abit here? |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
