E34 (1989 - 1995)
Mystery Misfire
Hey BMW owners! So my 1990 M20 525i has been taking a little bit too long to start, idling rough, and has an incredibly frustrating misfire, yet no check engine light. Well naturally I did some diagnostics and online investigating. After checking just about everything I came to a dead end and resorted to the replace random parts technique. Of course this changed nothing, so I searched online some more. A thought I had was the crankshaft position sensor, the main sensor used for ignition timing, makes sense. When I looked online at the symptoms of a failed or failing sensor, almost all said the call won't start at all. I found the resistance spec for the CPS (540 Ohms +-10%), then I tested it and read out 460 Ohms. Although technically out of spec, it wasn't far off, so I thought it was okay. It wasn't until today that I decided to check the crank sensor once more, now it was at 3 Ohms! It ran the same as it had before, and still no check engine light. That's when I got curious, I disconnected the sensor completely and STILL no check engine light. Not only that, the car ran EXACTLY as it did with the sensor connected. So from this experience I've come to the conclusion the check engine light is either completely useless, or my ECM doesn't know how to store codes. Anyway, I've ordered a new CPS for $37.61 at Eeuroparts.com, compared to Autozone which stocks it for $119.99. I should be getting my package soon and I will let you all know if my car magically runs perfect or if this is just another random part.
Year: 1990 Model: 525i Transmission: 5 speed Mileage: 250k |
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
As to your misfire, check your distributor cap, rotor button, plug wires and plugs very carefully. You may find the source of the misfire upon inspection. If you haven't replaced them in a long time, and your wallet allows, I would recommend replacing them if it has not been done as part of the routine maintenance. Another possible cause of a misfire is a faulty fuel injector. I’m 99% positive that your 90 model DME does not have the capability of detecting a fuel injector fault. I would look into a faulty fuel injector as a possible cause. Good luck.
My plan was if this CPS doesn't solve my problem I would investigate the fuel pump some more. Also I checked the AFM and the reading wasn't as smooth as I would hope as I pushed the flap open. As for that I got the Miller MAF conversion kit, I just haven't gotten around to installing it. I must be getting close to fixing it because I'm running out of parts to replace.
I would still recommend you check the dizzy cap. It still sounds electrical in nature. Hope you get it sorted soon.
Cold start problems on an M20 engine - strongly suspect distributor rotors and wires. Microcracks in the plastic and insulation permit moisture to enter and screw with charge generation and transmission. You've changed the wires - good. Please change the distributor and rotor etc. $150 for OEM. As Steve mentioned, this is a general maintenance item. And you do have a car problem. And your engine will run better in any case with new ignition equipment.
Also change the fuel pump, its regulator, and the crankshaft position sensor. Under $300 oem for all three. If not you'll have no start problems after this over the next 2 years. |
Please search for and download the searchable bentley manual for E34s and the troublshooting tables from the bentley manual. All the information about fuel pressure etc can be found there, and this is regarded as an invaluable tool to understand your car with.
So I installed my new MAF conversion, which I must say, is absolutely fantastic. Along with power gains it seems like my misfire has gotten SLIGHTLY better, and fuel economy is back to normal, for now. Considering I don't know when the distributor was last replace I figure I'll probably pick up a new one anyway. Should I just replace the cap, or the rotor as well? It's really frustrating diagnosing a car with no check engine light.. The problem is intermittent, sometimes it drives perfectly, others I can hardly stand being in the car. The idle and drivability quality always vary together, if it purrs it runs great, if it idles rough it drives that way too. I believe it to be a fuel system problem, mostly because whenever I replace a fuel system component it seems to drive much better when I go out for a test drive. The next day it's usually back to it's normal misfiring state, crushing my hopes and sense of accomplishment. I'm thinking it may be the O2 sensor or TPS, even though I tested both and they seem to be alright. I really wish I knew someone who was BMW savvy who I could take it to, but I do have you guys, so here are ALL the symptoms I can think of. I'll add more if I forgot any.
-Poor fuel economy, was 14 but today I reset it and it was 20 -Economy gauge on instrument cluster won't go below 20mpg no matter what -Fuel gauge erratic, sometimes dead on, sometimes it cuts out -Idle isn't smooth, sounds like it has a wider camshaft -Misfire, seen on tacho, heard from exhaust, and definitely felt by passengers, occurs most often with less than half throttle around 1500-2500RPM -Lacking power -Long cranks to start -Occasional groaning sounds from engine that varies with RPM, I think water pump -Soft clanging from transmission in neutral, I think clutch bearing -Bogs down for half a second when clutch is let off, then takes off -Randomly get a "COOLANT LEVEL" notification from dash when car is turned off or before starting -Fuel pressure 38psi at idle, 47psi without vacuum I'm planning on replacing the water pump, clutch, distributor, and crank sensor. Once I do that I'll have a 100% new ignition system. I think the fuel level sender may be messing with the fuel gauge and economy gauges on the dash, I may or may not replace it. I would be ever grateful if you would all share your wisdom with me!
how many more times would you like us to say dizzy cap? change the rotor at the same time. i replaced the one in my M40 and the two in my M70 engine, all up was around $500 so probably around $150 for just one set for your car
Sounds like you may have a vacuum leak somewhere as well, probably the cause of your bog. Clean the idle control valve, very often the cause of irratic idle. Valve adjustment, the M20 requires a valve adjustment right? You just weren't done with the tune up
Winter Rules
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
I tested for vacuum leaks with propane and couldn't find any, so unless there's a tiny tiny leak in one of my intake gaskets then it's air tight. The vacuum line and all intake gaskets are new so I doubt it, but I'll do some further investigating if the problem persists. I also ran my fuel pump through some tests: operating pressure = 38-47, engine off pressure = 44, max pressure = >100, current draw = 3 amps. Since the fuel pump checks out you'll all be glad to know I'm finally ordering a new distributor cap and rotor, luckily only $75 for OEM. Even though it acted up today my average MPG is about 18.8, but I'm going to assume that's from the MAF conversion.
On another unrelated note, does anyone know what sensor(s) the fuel economy gauge uses? My fuel gauge is also temperamental so I'm thinking both require the fuel level sending unit. I suppose another possibility is the gauge itself has something blocking it from dropping below the 20 mark.
I believe that the MPG gauge operates off of vacuum, but I'm not 100% on this.
All I have to do to get my MPG to drop to 0 is to floor the accelerator
The MPG needle (the constant moving thing under the Speedo) operates off vacuum.
The fuel gauge works off the level sender Sent from my SAMSUNG-SGH-I747 using Bimmer App
![]() Do you know where the gauge get it's vacuum from by chance? like brake booster, intake manifold, throttle body?
Check this out Post #4 in the following link: MPG Gauge-How Does it Work? Quote:
), but the actual MPG guage on the dash just below the tachometer. Microtesties, can you clarify?
I think that the link i provided is explaining the active, moving needle below the spedometer.
Ok. I certainly don't have much knowledge about it, so I will take his word for it.
It's all Greek to me anyway. I never really cared how it got there, I just trusted that it was accurate, being engineer by BMW techs and all...
So does anyone know where the gauge gets it's vacuum? Is there a physical hose or does it read the output from one of the sensors?
im pretty sure theres a physical vacuum line that goes behind the dash...
#25
Sent from my Desire HD using Bimmer App |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
